Question Copy+ to copy progs from 1TB to 2TB drives?
MattBGB
Joined
Nov 3, 2009
Messages
35
Reaction score
Points
Hello,
I have an Amstrad DRX780 Sky+HD box which is getting very old now, in which I installed a 1Tb HDD a few years ago.
I have just bought a DRX890 from what looks like a very popular and reputable seller on Ebay (I know, I know!) which has had a 2Tb HDD fitted.
So, my question is... can I use Copy+ to copy the recordings from the old 1Tb drive to the new 2Tb drive?
I have read many forums, including those on the Copy+ website itself and they all seem quite old and contradict each other as to whether Copy+ can do this.
Some say that Copy+ can't cope with 'Darwin' (whatever that is - but I presume my existing Sky box is Darwin) and that it can't copy recordings that are on this system.
Others say Copy+ will try to format the new drive and will basically turn it into a 1Tb drive as that's all it can cope with.
A few others say it can do the whole 2Tb but get very confusing as to whether it can copy recordings etc....
I'm really confused about it all.
Should I just spend 20 quid and use ExPVR instead and will that do it ok?
M
Copy+ is no longer an option, but using ExPVR its definitely possible to copy over your recordings. Have a look in the ExPVR forums for further info.
Thank you! It's what I suspected but that's definitely clarified things for me.
Will invest in ExPVR and try that.
Thanks again
M
Quality vs. Convenience: How do you consume your movies & TV shows?
Back
