copy sky hd to pc by usb
Discussion in 'Sky Digital TV Forum' started by mhs, May 3, 2007.
  1. mhs
    mhs
    Does any body know how to copy sky hd movies to pc by usb or any connection as fast as usb?
  2. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    you have posted this in the wrong section....there is a dedicated HD section..
    at the moment, without spending a fortune on component capture cards etc, there is no way to copy the HD movies in HD to watch on another system.....and if you simply copy across the raw data then you wont be able to watch it as it will be encrypted in a way only your sky box can decrypt....this last method is only useful if you want to make space on the sky boxes hard drive, however im not sure you'd be able to copy back across, thats assuming the the USB port is even working...
