Copy programs from humax to laptop
Discussion in 'Digital TV & Video Players & Recorders' started by bobfleming, Jan 6, 2012.
Tags:
  1. bobfleming
    bobfleming
    Jan 6, 2012
    7
    I have a humax PVR-9300T (with HDMI port) and a couple of laptops with only USB, not HDMI ports.
    I would like to be able to move some programs from the humax to the laptop for viewing on the latter. From what I read I think this is possible. So, given I am correct, how would I do this and what hw/sw would I need to make it happen?
  2. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,196
    Redditch
    +4,111
    It's not possible. Computer hdmi ports are outputs only. Only way other than recording the output directly using a DVDR/VCR is to remove the HDD and connect it to a PC running software that understands the file system.
  3. bobfleming
    bobfleming
    Jan 6, 2012
    7
    So even though the PVR has an HDMI output, there is no way to connect this to a laptop USB port and copy over the data?
  4. CARLOS
    CARLOS
    Feb 11, 2001
    6,520
    WEST MIDLANDS
    +1,425
    Nope, strangely the older model Humax 9200 had a USB port for this very purpose but they decided to remove it on the 9300 :rolleyes:
  5. noiseboy72
    noiseboy72
    Apr 24, 2011
    5,419
    +1,458
  6. bobfleming
    bobfleming
    Jan 6, 2012
    7
    Well that blows. Shouldn't it just be a case of getting something like an HDMI to USB connection though? HDMI out to USB in, job done?
  7. noiseboy72
    noiseboy72
    Apr 24, 2011
    5,419
    +1,458
    I think you probably need to understand a bit more about HDMI and USB.
    USB is a serial digital connection in and out of a computer. HDMI carries video, anti copy information and monitor capabiliities, not to mention audio and potentially device control.
    To connect one to the other, you need to decode all the information and re-package it in a format the computer understands. THe Black Magic Designs page features a USB 3 interface that does precisely this.
  8. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,196
    Redditch
    +4,111
    You can convert the analogue composite video output os s-video output to digital using a usb digitising device.
    Eg
    KWorld USB2800D USB DVD Maker direct recording of DV content to DVD disc from UK | eBay
    Don't expect the perfect results you get from a direct digital copy of the original data.
  9. celsius
    celsius
    Jun 1, 2008
    458
    28
    +39
    The first reply is still the most "practicable" way of doing it.
  10. bobfleming
    bobfleming
    Jan 6, 2012
    7
    Removing the hard disk? Not going down that road, I want a simple wireless or wired solution.
    So if the general requirement is to be able to copy programs from a pvr to a laptop or pc via a wired or wireless connection, what would I need? Different pvr? HDMI equipped computer?
  11. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,196
    Redditch
    +4,111
    Different pvr. In the Humax range
    Freeview SD 9200
    Freeview HD HDR FOX T2
    Freesat Foxsat-hdr.
  12. bobfleming
    bobfleming
    Jan 6, 2012
    7
    OK. Thanks to all.
