Copy Ipod back onto Computer's itunes folder ?? Help!
Discussion in 'Headphones, Earphones & Portable Music' started by geewhizz, Oct 18, 2005.
Tags:
  1. geewhizz
    geewhizz
    Jan 2, 2005
    2,490
    +91
    Well i stupidly deleted my itunes folder and all my music, Now i want to put itunes back to the way it was.
    Now this is where it gets complicated. I cant copy and paste ( Drag & Drop )from the ipod's hard drive to my hard drive ( it wont let me, although i've done this before )
    I have tried " Podutil " Ipod agent " Podplus " Copypod " Ephpod " And not one has worked, All the programs either lock up or they copy only one song.
    Ipod 4g Colour..
    Any help appreciated
  2. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,267
    +68
    Try Sharepod.
  3. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    I did just drag a drop a few days ago from my 3G Ipod 20gb using window file explorer. The key is just to ensure you have the "Show Hidden Files and Folders" clicked. So you can see the music file on your IPOD and just drag and drop the Fnn folders over to your PC.
    EDIT: Just reread your post, you have a 4G Ipod, so maybe they disabled this ability??
    Andy
  4. geewhizz
    geewhizz
    Jan 2, 2005
    2,490
    +91
    Nope that didn't work either although i have traced a possible hard disk problem. Something like chkdsk ? so i will wipe it a fresh and do it the long hard way.
  5. CLH
    CLH
    Apr 15, 2002
    2,159
    38
    +21
    Dunno if this is even relevant but have you "checked" the iPod for hard disk use?
