copy DVDs
BobBob21
I have now lost the last DVD to scratching that I ever want to.
Have decided to create copies of all my DVDs to enable me to use the copies in my Panasonic and Denon DVD players (neither support the compressed downloads very well - panasonic has no sound)
Nero wont copy them as they are copyrighted... what is the best way to do this to ensure maximum compatibility with DVD players (I am aware of the + - issues)
Ultima
I use anydvd with DVD2one and burn with copytodvd. I always use Ritek branded disks and never had a problem with compatibility issues.
The programs I use aren't free, free ones to consider would be DVDfabdecrypter with DVDshrink. Use Nero (since you already have this) to burn them to disk.
Regards
Martin
Pat_C
I don't think I've ever scratched a DVD. What are you doing to cause this?
Reaperman
FazerThou said:
Any DVD and CloneDVD2 for me to back mine up and decent blank DVD's
I use this combination to "archive" my DVD's too...;)
1 off payment for both and get free upgrades via automated downloads..:thumbsup:
overkill
It's easily done. There was an article recently on just how easily. Only very few discs survived the tests they ran and some just had to be sneezed at to scratch. Deep scratches at the very least get the error correction working overtime, and if too deep shag the disc. Either way it was not a happy set of bunnies that reported back after the tests............:cool:
overkill
Ditto.
Woodywizz
I use "DVD Shrink" then burn with Nero - no problem at all in backing-up any of my discs; I use the 'non-compression' setting and burn to 8.2GB dual-layer discs.
partyweb
For me it's not just the scratches I'm worried about but the centre of the disc cracking with repeated removal from some of the cases. :mad:
markymark34
dvd shrink works very well and is simple to use.
If you already have full nero (with Recode) then you could buy anydvd or get a trial version if you want to try it and then all you have to do is open anydvd before nero and away you go!
stevefish69
Another thumbs up for DVD Shrink and Decrypter here.
Have even sorted out the dreaded Sony Red discs now !!!
mij
DVD Decrypter, FixVTS, RipIt4Me & DVD Shrink 3.2 are all free programmes that make it very to simple to backup DVD's.
It is also just a few clicks of the mouse to use them once insatalled as RipIt4Me automates the process.
lostinspace
You must be doing something wrong to have a 100% failure rate of discs. I've got about 800 in my collection, and must have swopped/sold another 300 over time, and have had one go faulty, one faulty on delivery, and I've got T1 which has gone milky.
I don't know anything about the survey you mention, but in my experience, if you look after your discs they last OK.
Why not take a couple of faulties to a repair place and try that? Where I used to work we had a machine which repaired scratched discs, and we only ever had about 3 failures.
I agree about centres getting cracked, though. That's a bigger problem.
overkill
Sorry, did anyone say 100% failure? :confused: The test carried out was to see how many could stand the sort of wear and tear the average user gives them. Bear in mind that the vast majority (ie average) swallowed the whole 'indestructible' myth whole with CD, and now apply that to a medium that the tests show is in fact more susceptible to damage.
I agree totally that if you look after your discs, and in fact treat them like Vinyl, then they are fine. Most people however, and some of the crap I've bought second hand confirms this, treat them, with a contempt borne out of lies about CDs durability and, as it's a 'video medium', like VHS tapes. They ain't.
Of discs I've bought new only a very few have gone belly up, and as you say the centre cracking is a bigger problem. However, 2nd hand discs I normally back up before they do the DVD player repairable harm. Even ones claimed (as one I bought the other day was) to be in 'excellent condition'. If that's his idea of excellent, I'd hate to see what knackered looks like!:rolleyes:
lostinspace
Sorry, misread the OP. Whatever the failure rate, it's obviously high enough to :censored: him off.
There seems to be a lesson to be learned about buying second- hand though. With the prices of new, campaigned discs now coming so low even I can afford them, there seems little point in buying second- hand, unless it's something deleted etc. I've never bought second- hand, and probably never will.
P.S. What's an average user? I bet there aren't many of those on here!
overkill
I don't think there are on here. Most people who take hifi/AV seriously, just like people with any other 'interest', treat their gear with care. It's usually the 'child factor' or 'unenlightened' relative or friend that does the damage. However, since DVD is the biggest success ever in terms of a new medium, a lot of mr and mrs average (whoever, or whatever they may be!) must own a DVD player and discs. :D
I agree on buying software 2nd hand. I tend to avoid it if I can, as, since working in hifi, I've been a bit cautious of causing damage to digital players. As you say, with decent offers on the likes of Amazon and Play.com you don't need to go 2nd hand.
It's those two-disc special editions that are now deleted I tend to go for.
markymark34
whats up with the sony red discs?
havent been 'backing up' in ages so am a bit out of touch!
stevefish69
http://www.sonydadc.com/products.copy.arccos.go
Basically a pain in the bum but can be done :devil:
Use Decrypter to put an ISO image of the disc on your hard drive.
Open this using DVD Shrink, and rip as normal
Burn to Disc using Decrypter as normal.
bluevortex
I've just about finished backing up 24 series 1-4 (24 discs in all :boring: )
Its taken me 2 days using decypter/shrink/nero.
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
Latest News
Philips unveils A7507 TWS headphones and new rugged outdoor speakers
  • By Andy Bassett
  • Published
Philips FB1 soundbar will use Fidelio wireless platform
  • By Andy Bassett
  • Published
Philips announces OLED807 and 8807 The One TVs for 2022
  • By Andy Bassett
  • Published
Lenco launches 400 series turntable and speaker combo
  • By Andy Bassett
  • Published
AVForums Podcast: 26th January 2022
  • By Phil Hinton
  • Published
