Sure this a regular Topic, but searching hasn't shown anything for Win7 32b.
I make a master copy of video/sound files on a dedicated HDD, apart from the C-drive for Programs.
However, I don't always manage to make duplicate copies on external drives.
I've been prompted to explore a software option as in the current Computer Shopper they are offering a free download (it says),"Ablesoft Backup 2014" - it's a title I don't know, but I'm suspicious of the name "Able-" as this sounds like it is promising LOTS....
[-One interesting feature it claims it will organise backups even if the external drive isn't connected - meaning it waits until it is, then presumably, it copies-over - hopefully (promps), when there is time to do this. ].
Does anyone know this software, is it without snags - and does the "missing drive feature" work as it implies, without a hitch?
Alternatively, can you rec. software that does this?
Typically, the files can build up to 10's Gb, before I get the external drive out of the Loft.
These drives are 1) eSATA, . . . . 2) USB3. they work fine, but it's rather tedious finding which
files are backed-up, and which aren't.
