Coolwebspace virus
Discussion in 'Desktop & Laptop Computers Forum' started by Greg Hook, Jul 17, 2004.
  1. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    23,576
    2
    In a secret location with Jennifer Lawrence
    +10,564
    Remember seeing a thread on here recently with a problem someone had with a virus/trojan called coolwebspace.
    My mum's computer has this problem and I seem to remember a solution being given on the thread, but I can't find it via a search.
    Can anyone point me to the thread in question.
    Greg
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    i keep getting one (cant rid it) homepage gets set to about:blank is this the same one?
  3. Greg Hook
    Greg Hook
    Nov 25, 2001
    23,576
    2
    +10,564
    yes, thats it!
  4. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Download CWshredder.................... it'll fix the problem.
    Click Here !!!
    Sean.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Hmm found it rebooted and it was still there! any ideas?
  6. Brogan
    Brogan
    Oct 9, 2003
    7,582
    Cary, North Carolina
    +482
    Try this: format C:
    You may need to do some reinstalling afterwards though...:D
  7. HMHB
    HMHB
    Nov 11, 2001
    27,230
    Nottinghamshire
    +6,139
    No you won't - that command is wrong and will not format !!
  8. Roachman
    Roachman
    Jul 11, 2004
    215
    Leicester
    +9
    GregHook,
    Did you try the CWshredder ? Did it detect anything ?
    I helped a friend this week with the same problem, so I tried the CWshredder prog which detected and removed the culprit.
    I rebooted and then ran AdAware which found another 50 odd probs, deleted/quar
    antined those, rebooted, and his computer is now working ok (touch wood)
    Lee.
  9. ancientgeek
    ancientgeek
    Stop using Microsoft software?
  10. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    john,i want to format my hd using console but if i try to it wont format,i type in"format c:/" and it warns me that i will loose all on disk, format y/n,if i say yes it just ignores me ,any ideas?
  11. Greg Hook
    Greg Hook
    Nov 25, 2001
    23,576
    2
    +10,564
    Yes it did work Roachman.
    Ran CWShredder, it found it and removed all the items. Unfortunately came back though, so updated my Mum's XP to service pack 1 and all latest items, ran CWShredder again and it removed it again. Hopefully gone for good now
  12. HMHB
    HMHB
    Nov 11, 2001
    27,230
    Nottinghamshire
    +6,139
    I normally format disks by either booting up from an old Windows 98 floppy boot disk or by booting up from a bootable Windows XP hard disk. If you don't have a win98 boot floppy I believe you can download from the net.
    In Windows XP by the way, it won't work if you put the "\" in - the command should be format c: (I always thought it was the same on win98 etc also)
  13. The Dude
    The Dude
    May 21, 2004
    6,568
    Beverley, East Yorkshire
    +2,993
    I'm not sure if you're joking here or not.. ? :confused:
    but, you can't format your c: drive with windows running, whatever command you use..
    If you're wanting to start over, the easiest way is to boot using the 2000/XP CD, then during setup delete the existing C: partition and recreate it, you then get the option to format it..
    Apols if i've missed the gag here?? :blush:
  14. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    thanks all for replies, :thumbsup:
  15. Brogan
    Brogan
    Oct 9, 2003
    7,582
    +482
    You can if you're running Windows from a floppy... ;) :D
