Quantcast
Cooling hot AV Cabinet
Brendas
Dear members,
I am in process of setting up Home cinema+Hifi system. Right now trying to design the AV cabinet that will be made bespoke.
One concern based on reading multiple thread I have is on the AVR (Arcam) getting hot. I am planning to install AC Infinity AIRCOM T8, Quiet Cooling Blower Fan System 17"
However I also understand that there need to be another fan fitted at the back to take the hot air out. In my case the back of the cabinet will be wall so would I need to fit the fan in the wall and cut a duct through the wall to take the air out? In that case am I not creating a 8-10 inch diameter hole that will constantly take cold inside the lounge. Hope I have understood the two fan solution right and this is the only solution. Thanks for your time to help.
