Cooling fan needed
Discussion in 'Home Cinema Building DIY' started by redmax, Feb 3, 2003.
  1. redmax
    redmax
    Sep 13, 2002
    1,079
    ESSEX, UK
    +43
    I want to change my very noisy cooling fan to my convergence board in my Seleco SVP 400.
    The fan installed at the moment is a Sunon 30x30x10mm.
    Does anybody know where I can buy such a fan.
    I have checked obvious places like Maplins,Overclockers etc but cannot see anything that small.
    BTW it is listed in Sunon's catologue so I just need a dealer.
    Even better would be to find a fan that is the same size but quieter and moves more air.
    Any suggestions please.
    :confused:
  2. Cheng
    Cheng
    Dec 19, 2002
    391
    +7
    No chance in getting more air AND quieter for this size....why don't you try something bigger, as it will move more air AND quieter i.e. 60mm, 80mm?
  3. redmax
    redmax
    Sep 13, 2002
    1,079
    ESSEX, UK
    +43
    I'm governed by the room I have inside but I'll see if that is an option.
    Any suggestions where to buy Papst fans or Sunon?
  4. Cheng
    Cheng
    Dec 19, 2002
    391
    +7
    overclock.co.uk is by far the cheapest I've found
