Cooling down my amp
Discussion in 'AV Receivers & Amplifiers' started by Nixon, Aug 5, 2003.
  1. Nixon
    Nixon
    Hey All,
    I am very worried about how hot my amp gets. It is a MArantz 4200 and it is in a pretty confined space. This is the only place in the room where it can go and I was wonderin whether there were any gadgets or soforth that I cound buy?
  2. adc2000974
    adc2000974
    My old Pioneer VSX-D510 & Sony DE685 used to get pritty hot but so does most other av equiptment.
    Under most conditions thats fine, unless you experience constant shutdowns, then i suggest u need to move away from or exclude > things like direct sunlight > or external heat sources.
    Other measures you can take are simple things like using fans, dont put the volume up full crank, and make sure there aint any loose connections > and check your speaker Impedance which causes additional heat buildup.
    Ive had to deal with all these problems myself due to having a small room, by all means get back to me on that one, hope to be of some help.
    Regards
    Adam C
  3. dts_boy
    dts_boy
    Nov 26, 2001
    2,615
    Manchester suburbs...
    +178
    try fitting a simple extraction fan system, based around a computer PSU and fans - i have done this in the past to good effect!
  4. Gatto
    Gatto
    Take care of heat build ups, as in the long run it can result to a shorter lifetime! Try to set good ventilation by installing small fans and keeping the Amp in a ventilated area segragated from other equipment! Ive been working in the IT industry now for 8 years and heat build ups are quite a nightmare for an electronic device! As most of the devices just freaks out or instantly shut down for not damaging the internals
  5. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    Nixon...all amps should have sufficient ventilation space around them to allow adequate cooling,and certainly amps like yours were designed for convection cooling to be sufficient under normal conditions.....if it must be used in a confined space,then some means of increasing airflow such as fans will help your problem,but noise is almost always a slight background feature of this solution...I know,I have a set of Krell KMAs,which by the way run extremely hot,even with the fans,and have been totally reliable...but they were designed to run that way.
  6. Nixon
    Nixon
    Hey guys, thanks a lot for all your posts, but how would I install some fans? I built my own computer and am very interested in all aspects of electronics, so any help would be appreciated.
  7. Smurfin
    Smurfin
    Aug 13, 2002
    21,421
    +4,353
    Comer had some useful tips on water cooling ;)
