Cooler Recomendations for 9950BE
Discussion in 'Computer Components' started by westons1, Jun 17, 2009.
  1. westons1
    westons1
    Jul 8, 2007
    3
    Falmouth, Cornwall
    Hi guys,
    Can Anyone recommend a Suitable cooler for My Gaming HTPC, as you can guess, I need it to be very quiet for normal use but powerful for when i'm gaming and OC'ing
    My System Is....
    Phenom X4 9950BE
    Antec Veris Fusion Remote Max Case
    Msi K9A2 Platinum
    Corsair XMS2 (4 x 2Gb)
    Asus 4850
    Thanks In Advance
    Steven
  2. eddyx11
    eddyx11
    Mar 16, 2007
    148
    UK
    +26
    I've had good results with the Zalman 9500 and 9700 (the latter if you have a big case) coolers. With the AMD cpu's you can even use the stock mountings instead of removing the motherboard as with the s775's.
    I've a 9500 on a 7750be and it runs cool...
  3. westons1
    westons1
    Jul 8, 2007
    3
    Falmouth, Cornwall
    I think I might need something a little more heavy duty, like the TRUE 120 Extreme or a Scythe Mugen 2.....
  4. westons1
    westons1
    Jul 8, 2007
    3
    Falmouth, Cornwall
    I want to get the biggest OC' I can off air alone.....
