Cool/quieten my pc
Discussion in 'Desktop & Laptop Computers Forum' started by darren_eaf, Jan 2, 2007.
  1. darren_eaf
    darren_eaf
    Oct 9, 2005
    559
    +30
    Hi guys,
    I'm wanting to make my computer run quieter and cooler for as cheap as I can.
    My computer spec is here
    I've been looking at adding something like this
    Can anyone think of anything else that would be worth changing, power supply, other fans etc.
    Thanks :thumbsup:
  2. evo6
    evo6
    Mar 14, 2006
    161
    +13
    I dont know the size of your case, so I'm not sure what will fit. I had the artic cooler a while ago, but ended up going to the Scythe Mine. Far better cooling, even when I do some serious overclocking. Both are very quiet coolers.
  3. DLPMaybe
    DLPMaybe
    Mar 16, 2005
    945
    +54
    Open the PC and stop each fan in turn with your finger. Identify the loudest and replace it. Repeat this until you are happy with the sound level.
  4. badbob
    badbob
    Jan 21, 2006
    4,591
    +318
    Only stall the fan for a couple of seconds.
    What appears to be the loudest component?
    CPU fan
    Motherboard chipset fan
    PSU fan
    Videocard fan
    Hard drive
    Case fans
  5. darren_eaf
    darren_eaf
    Oct 9, 2005
    559
    +30
    I haven't looked into that yet.
    I'm just guessing that the cpu fan is the nosiest?
    I just know that when I first switch it on, it sounds like a jet engine, and does every 20 minutes or so.
    Seeing as it's only every now and then, this would rule out the harddrive?
    Thanks for evryones replies so far, but keep them coming :thumbsup:
  6. stainlessstan
    stainlessstan
    Dec 26, 2006
    98
    +10
    You could be right but check that it isn't your DVD/CD drive that is spinning up, especially if you have a tendency to leave discs in. These can be very noisy.
  7. Ruperts slippers
    Ruperts slippers
    Dec 18, 2004
    8,233
    Earth
    +4,233
    Its probably your video card ,but it then again it could be one of your media drives.
  8. darren_eaf
    darren_eaf
    Oct 9, 2005
    559
    +30
    Do you think getting one of these would help?
  9. Ruperts slippers
    Ruperts slippers
    Dec 18, 2004
    8,233
    Earth
    +4,233
    Just do the finger test or use a pencil ,poke it in the fans and see which is the loudest ,i found the graphics card to be the loudest .I replaced my case fans with some acoustifans ,and the cpu cooler with an evo cooler ,but the graphics card is still whirring away.
  10. badbob
    badbob
    Jan 21, 2006
    4,591
    +318
    You need to find out what's making the most noise. Do that before changing cooling, because if you don't replace the loudest (ie chipset fan at 6000rpm) replacing a fan that's quieter (ie cpu) won't make much difference. Quiten the loudest and the system noise will be considerbly lower in noise.
  11. MarkSS
    MarkSS
    Apr 10, 2006
    423
    28
    +30
    Quite likely to be the Northbridge fan. Its certainly the noisiest left in mine and exhibits similar behaviour, screaming at startup, settling down to a background hum but occasionally whirring up again.
    http://www.quietpc.com/gb-en-gbp/products/northbridgecooling
    I bought one of the heatsinks above when I built the PC but couldn't use it as the two terratec DVB-T tuners I put in extend over the chip. Considering adding the Thermalright HR-05-SLI listed at the top of that page as it should avoid the cards.
  12. Oldalez
    Oldalez
    Oct 5, 2006
    96
    With your GPU you should be able to get away with a passive cooling solution - one of the Zalman products perhaps
    Having recently installed a Scythe Ninja in a PC I can certainly recommend them
    Have to agree with previous poster though - unless you target the components making the most noise it will all be for nothing.....
    I used a Reserator 1 on my previous PC - awesome piece of kit, but was cooling a Prescot 3.2 CPU and 9700 GPU with it so couldn't overclock in the summer months :(. Made for an extremely quiet system though and relied upon the PSU fan for exhaust and one intake fan at the front
  13. darren_eaf
    darren_eaf
    Oct 9, 2005
    559
    +30
    OK, I've done the "finger test"
    The fan that makes the most noise during startup/every 20 mins is the one on the processor. The fan that is currently on it is this one.
    The fan that is the most noisy the rest of the time is the one on the graphics card.
    There are no other fans in the case other than those two and the one in the power supply.
    There is mesh output on the side of the case for ventilation, as seen in the pic attached.
    The circular mesh section is where the fan from the processor exhausts, using a funnel type piece of plastic, again picture attached.
    With this now in mind, what do people recommend?
  14. peskywinnets
    peskywinnets
    May 8, 2005
    1,157
    48
    +59
    Looking at that second pic, here's my prognosis....
    Removing the wastepaper basket from the top of your CPU might help somewhat (not with the noise, but from general scraps of junk falling into your 'puter where people miss the bin :D )
  15. Oldalez
    Oldalez
    Oct 5, 2006
    96
    Looks tricky
    The lack of vents in the back of the case might cause heat build up if you swap out the CPU cooler for something else
    You might be able to fit a Sythe or similar and direct the fan towards the PSU but this could cause PSU overheat problems
    You might try cleaning the case/heatsinks/Fans etc - looks dusty - and maybe look to replace the CPU fan with a quieter similarly rated fan?
    As for the GPU a passive cooling option might be a possibility, or alternatively one of the quiet Zalman GPU fans?
  16. badbob
    badbob
    Jan 21, 2006
    4,591
    +318
    How do you know a Ninja will fit his case? He hasen't given any info how wide his case interior is. I have one in a Stacker
  17. Oldalez
    Oldalez
    Oct 5, 2006
    96
    I don't - hence the word 'might' :)
  18. darren_eaf
    darren_eaf
    Oct 9, 2005
    559
    +30
    It's a Micro ATX case, don't know if that helps.
    I've pinched some pics from one being sold on ebay, which I have attached.
  19. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    Get a New case with a rear 120MM fan, recently got an Antec NSK4400, even has a 430Watt power supply..., so recomend getting that...
    Then you have enough room for a decent CPU cooler..
    Add and Akasa Amber 80MM Fron fan, if you motherboard chipset has a fan on, I don't think Intel ones do, but replace it with a Zalman Passive Northbridge Cooler..
    Also get a Passive Graphics Card cooler or one with a Low Speed Fan..
    Case: £50
    80MM Fan: £6
    Northbridge Heatsink: £8
    CPU Cooler: £25-£40
    GPU Cooler £15-30
  20. darren_eaf
    darren_eaf
    Oct 9, 2005
    559
    +30
    Where did you get your case from?
    I've found it with a 380W power supply, but not 430W.
    Cheers, and thanks for the help :thumbsup:
  21. Babylon
    Babylon
    Sep 24, 2002
    108
    http://www.sheppeyscum.com
    +6
    You could try what I did which kind of killed 2 birds, I had the same problem of to many hard drives and to much heat and an underpowered power supply.
    Well I had another HTPC case that I upgraded from,So what I did was buy 4 SATA Dual Port Backplate Adaptors and put them in my New case and connect them to the SATA headers.
    [​IMG]
    I then put a plug on the back which connects to the power supply plug
    [​IMG]
    [​IMG]
    I then put a plug on the buck of the old case and connected that to it's power supply,
    [​IMG]
    Next thing was to put my hard drives in the old case and and connect them to the other 2 SATA back panels and to the power supply,
    [​IMG]
    Then just connect the 2 cases together with SATA cables and the power on cable
    [​IMG]
    and Switch on, Now when you switch on the new case, the old one comes on as well, No one power supply is being pushed that hard so they stay cool and the temperature controlled fans stay at low speed, The hard drives have loads of room to breath and stay really cool and have bean able to disconnect a couple of fans, I have 2 IDE drives in the new case and 3 SATA drives in the old with a spare SATA connection for one more drive, could also put a cheap SATA card in the new case and have 2 or 4 more drives.
    I'll be fair as to say that I already had the spare case,power supply,the 2 plugs and the SATA cables so only had to buy the SATA back panels at £15, But it's just another idea.
  22. RockySpieler
    RockySpieler
    May 23, 2005
    1,661
    Snaking the Lineup
    +115
    Babylon,
    Great idea, looks good in the Glass Rack.
    Please can you detail how/where the GRN/WHI wires for the second PSU works (clearly you do not want the SATA PSU to start/stop out of sync)?
    I could be interested in something similar, my Tsunami tower just would not look good on its side, in a AV rack. I suppose any dead DVD player would works as an enclosure, obviously dead desktop at local tip may be better, even their PSU would work.
    Do you boot off the single PATA drive in the first picture?
  23. NaTT
    NaTT
    May 27, 2003
    1,123
    Abbots Langley
    +77
    you can get those back plate adapters with a molex power adapater pass through in between 2 the SATA ports.
    Upshot for me is that I'm now adding Disks that power off the mian PCs power (it's passive and man enough) and I'm putting the HDDs in individual silent HDD cases, which I stack at the back of my rack.
    Just need to make sure I disconnect them before pulling the PC out:eek:
    Oh and before I'm asked, I don't know which purchase said adapter came with, I've not seen them else where
  24. darren_eaf
    darren_eaf
    Oct 9, 2005
    559
    +30
    Thats probably going a bit excessive for what I want.
    I only have one hard drive and don't do much gaming. I just want it to be nice and quiet and cool.
    I'm looking at the Cooler Master Centurion 534 case to replace the one I have at the moment.
  25. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
  26. Babylon
    Babylon
    Sep 24, 2002
    108
    +6
    There are 3 wires to use, The Green one, The Purple one and a Ground Black one, I just used the black wire nearest the edge next to the green Wire, Just run these 3 wires from your main case to the corresponding colours on the second power supply and bobs your uncle.
