Cool HTPC with DVI
Discussion in 'Desktop & Laptop Computers Forum' started by northernmunki, Jun 4, 2005.
  1. northernmunki
    northernmunki
  2. marky_h
    marky_h
    Dec 19, 2002
    355
    Hampshire, UK
    +23
    The Asus Pundit has a DVI output, although it's a barebones, not just a mobo. The AOpen is just divine...
  3. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Socket 479 would seem the obvious way to go, with the Aopen being my personal preference because it allows for a graphics card, tv tuner and any additional expansion cards to be fitted without issue. Add to that a quality HTPC case, quiet PSU and slick software setup and you will have a combination hard to beat even with decent quality stand alones. A cheaper alternative would be a Northwood 800fsb based P4 setup with a sub 3 gig processor giving enough power but with good heat characteristics.
  4. northernmunki
    northernmunki
    Im thinking of using the following for a queit HTPC;
    Asus P4P800-VM Motherboard
    ASUS CT-479 Adapter for Pentium M
    Pentium M series, maybe 2GhHz or similar slower from ebay
    All inside a Silverstone LC02 case
    How does it sound, has anypne used the adaptor? I've read the BIOS needs updating before it will boot. Any work arounds?, If i'm lucky the BIOS may be new enough.....
