convertor woes .....
Discussion in 'Plasma TVs Forum' started by hogwash, Nov 21, 2004.
  1. hogwash
    hogwash
    Sep 7, 2003
    123
    Cheshire
    I bought a JS Tech vga to plasma convertor a few weeks ago, all was well until I swapped my dvd player ... the setup i have is below.
    Panasonic plasma <custom made vga – vga lead> < JS vga convertor > <scart>dvd recorder scart 1
    dvd recorder scart 2 ,scart> sky+
    I therefore loop thru the recorder for sky+ and output all video thru scart 1 on the recorder thru the vga convertor and into the plasma vga port.
    My problem: PAL dvd = perfect
    Sky+ = perfect
    Recording on hdd of dvd recorder = perfect
    NTSC dvd = jumpy , shaky picture with severe “interlacing” and ghosting, almost reminiscent of "macrovisionesque jitters"
    NTSC dvd with direct scart connection from scart 1 of dvd recorder to plasma = perfect
    I think, therefore that the problem lies with the vga convertor.
    Anyone got any ideas, I am reluctant to splash more cash on a component board for the plasma and a top dollar lead towit!
    emailed JS Tech am awaiting a reply
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Dr Sim will be with you tomorrow I'm sure. Perhaps he will post the results in the forum. What DVD recorder?
  3. hogwash
    hogwash
    Sep 7, 2003
    123
    Cheshire
    panasonic dmre85 (both scarts have rgb but scart 2 is non rgb for ntsc sources)
  4. guli
    guli
    Sep 3, 2004
    412
    16
    i have the same problem too
    if my component input is in ntsc mode, then switched off, and pc mode is selected (pwd6), whatever that is connected via the js rgb to vga converter will be juddery.
    Alex
  5. sjp21
    sjp21
    Apr 10, 2002
    288
    York
    +5
    Same problem here as well. DVD daisychained to SKY+ box. Fine for everything but NTSC discks. Only set up this weekend.
  6. hogwash
    hogwash
    Sep 7, 2003
    123
    Cheshire
    ooops I appear to have discovered a bug in the js convertor!
    Dr Sim has been in touch and I have arranged mine to be shipped back for investigation!
    here's hoping
  7. Twilliams
    Twilliams
    Oh my god cables cables everywhere. what do I use a Scart a VGA or an RGB for my New Panny TH37-PE30, have sky digital and a DMRE55 ro connect. dont no if im coming or going... :rolleyes:
  8. hogwash
    hogwash
    Sep 7, 2003
    123
    Cheshire
    i was like that when i was testing which inputs had the best signal from my many different sources! .... when you get straight you'll love it.
    best peice of kit i have ever bought the pw6 plasma!
  9. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    We're more than happy to check out the VGA unit, and see if we can make adjustments to the unit. Please contact me.
    Twilliams.
    The RGB to Plasma VGA unit gives excellent results with the PE20, so should be the same for the PE30. BUT, on the PE20 the VGA socket is on the front.
    All the best,
    Dr John Sim.
  10. Twilliams
    Twilliams
    cheers mate will look into that
    there only the one socket i guess for that so what i use for the DVD a decent scart? (THOR)
