Converting WMV-HD files to run on PS3...
Discussion in 'Playstation Forums' started by markmitt, May 3, 2007.
  1. markmitt
    markmitt
    Oct 11, 2005
    1,153
    Huntingdon
    +27
    Simply put, can it be done?
    I have looked in other threads, and tried different software such as Video 9 and MeGui, but always come back as error or invalid file type. I have quite a few bits of 1080p WMV-HD files that I want to stream across, but at this rate, I don't think it's going to happen.
    Perhaps in the not too distant future, an update will be made available to make it easier to access different file types. Or perhaps I would be better going down the route of installing Linux (although I have no experience of Linux at all). But in the meantime, is there a way to do it?
    Many thanks in advance...
  2. Sqweeky Badger
    Sqweeky Badger
    Jul 29, 2006
    528
    +33
    video 9 works for me, it mabe your pc
    try reinstalling windows
    convert in to 1080p or which ever takes your fancy, use mp4
    what i did was download a trailer off psn and pull it on to your pc and right click it and make a custom profile based on those resolution settings
    havent realy come across any other programs that will do hidef
  3. MaiaMan
    MaiaMan
    Feb 13, 2006
    146
    And how did the converted file look on the PS3? I did it and it looked blocky here and there
  4. markmitt
    markmitt
    Oct 11, 2005
    1,153
    Huntingdon
    +27
    Video 9 works for me as well, just not with WMV-HD. Doing a reinstall seems somewhat drastic just to view some hi-def material. You definately sure it's WMV-HD files that work, and not just WMV?
  5. Sqweeky Badger
    Sqweeky Badger
    Jul 29, 2006
    528
    +33
    1st they looked :thumbsup: no blocks just pure niceness
    2nd i think they were hd files the pic i showed you was origanaly a xbox 360 forza vid in 720p and that worked fine
    if you want more more more try here
    http://www.videohelp.com/
    just look around the how to section on the left:smashin:
  6. psikey
    psikey
    Oct 5, 2005
    7,839
    3
    South Yorkshire
    +1,048
    Don't recall having any problems with V9 & WMV-HD either. I do have CCCP installed though so maybe that has something to do with it.
  7. markmitt
    markmitt
    Oct 11, 2005
    1,153
    Huntingdon
    +27
    CCCP?
  8. Sqweeky Badger
    Sqweeky Badger
    Jul 29, 2006
    528
    +33
    Combined Community Codec Pack
    is a DirectShow filter pack specifically built for playing anime. It has been assembled by some of the most knowledgeable people in online anime distribution, and one of the primary design goals is to play as much as possible with as little as possible. The CCCP attempts to be as unintrusive on your system as possible.
