converting usa amp to uk amp
Discussion in 'AV Receivers & Amplifiers' started by CYRUStheVIRUS, Dec 19, 2003.
  1. CYRUStheVIRUS
    CYRUStheVIRUS
    Jan 25, 2003
    1,408
    41
    Berkshire
    +16
    Is it possible to convert a USA amp to UK one, has anyone done this, any idea of cost. (surely just changing power output)
    any help appreciated.
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,423
    Somewhere in South Yorkshire
    +5,823
    You will need a mains voltage transgormer, unless the power supply in the unit is already multi-voltage, which you can establish from the manual, or perhaps from a maker's plate on the rear.
    Something like this
    http://www.maplin.co.uk/products/module.asp?CartID=031219184921506&moduleno=13358
    but ensure that it's power rating is enough for the amp (again, this information from the manual or maker's plate). Th ones quoted here may not be sufficient.
    That should be all that is needed.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Or get a UK Power supply unit fitted by a service agent in the UK and then you should have no worries!
  4. CYRUStheVIRUS
    CYRUStheVIRUS
    Jan 25, 2003
    1,408
    41
    Berkshire
    +16
    sorry nigel, i rushed my thread, i know that a stepdown transformer can be used but i mean can i ask the manufacturer or suitable repair place to change the internal power supply.
    Has anybody done that.
    any idea for a decent amplifier 100w per channel or more.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Yep you can, should just be a case of ordering a UKpower supply (european) is the brand distributed in UK or europe? is the model available over here?
  6. CYRUStheVIRUS
    CYRUStheVIRUS
    Jan 25, 2003
    1,408
    41
    Berkshire
    +16
    its for a denon a1d
  7. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,567
    The Fylde Coast
    +12,909
    FWIW remember that there is more than voltage difference. US is 60Hz and UK 50Hz. Sometimes equipment can handle dual frequencis as well as voltage. However many do not. As a result, and particularly with Amps, a 100MHz hum often is introduced into the circuot because of these frequency differencies.
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    thats why you get a new power supply!
  9. brendank
    brendank
    Dec 13, 2003
    684
    drogheda, co louth,ireland
    +6
    sorry for butting in guys
    but i am facing same problem myself
    does this overcome both the frequency and voltage problem?
    how much would it cost
    cheers
  10. GaryB
    GaryB
    Nov 12, 2002
    5,387
    St Albans
    +1,294
    Fitting the mains transformer from the equivalent UK model if there is one is usually all that is required. Mains frequency is not generally an issue because the power supply rectifies the mains to DC anyway. You may find that manufacturers won't do the work as the unit would not have been subjected to the relevant UK BEAB and CE saftey tests so you will probably have to find a willing dealer.
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    For that you need to speak to a dealer with a work shop!
  12. a_911_man
    a_911_man
    I've jsut returned to the UK after working in the States and need to convert my equipment for UK use. Its:
    Harmon Kardon AVR230
    " " DVD22
    " " HKTS7
    Any help would be appreciated
  13. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    In theory it can be done but you need to find a transformer/power supply that provides the same or similar output on it's secondary side (at the higher input of 230V). As well check that the AC filter, if applicable, can handle the higher voltage.
    Frequency is not really an issue unless some internal electronics uses the mains frequency as a clock source (unlikely I would say).
    Obviously it can be done but it also might be costly, in particular if you use an original powersupply from the UK model.
  14. Peridot
    Peridot
    Aug 24, 2004
    2,977
    Newport, South Wales
    +293
    With a number of items to power, an industrial type transformer might be more cost effective.
    E.g. http://www.screwfix.com/app/sfd/cat/pro.jsp?id=16158&ts=52662
    Not exactly pretty, but it could power any amount of AV kit and can always be hidden away.
    You can normally pick these up second-hand fairly easily, or as building site 'surplus' from the right sort of pubs ;)
    They can also be hired from tool supply companies to confirm that the 50Hz frequecy is not a problem.
    _________________________________________________________________
    Regards,
    Dermot
