Converting .ts to SD DVD
Discussion in 'General TV Discussions Forum' started by jamesr, Oct 20, 2005.
  1. jamesr
    jamesr
    Is there any recommended software out there to convert HD .ts files to an SD DVD? Keen to covert something so my boss can take a look on a normal DVD player?
    Any help welcome,
    Thanks,
    Roger
  2. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,784
    Outpost 31
    +218
  3. James B
    James B
    Jul 29, 2004
    Yes you can do it, but I don't see why you'd want to. It won't be any better than a normal DVD, so why bother?
  4. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    It would make more sense to burrn the TS as a standard file onto the DVD and have the boss play it back on a decent spec PC on a standard monitor (which is likely at least to match 1280*720 and probably exceed easily).
    The difference between a DVD and HD on a PC is quite evident so just get him to imagine the difference on a 32" to 50" flat panel:)
  5. jamesr
    jamesr
    Thanks for the quick answers guys. svcd2dvd is exactly what I am looking for.
    Just to round it off, the boss is quite happy to watch it on his PC, its his missus that isn't. Anyway, I keep her happy with the DVD, she keeps him happy and he makes my life easier!
    cheers.
  6. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    So why bother downloading 4-5gig HD caps and converting them to an inferior format when you might as well get a 350/700meg xvid and convert it to dvd spec or just get an xvid/avi DVD player, either way you ain't watching HD.
  7. jamesr
    jamesr
    'cos I have them to watch in HD on my plasma which is great. Only doing him a favour by passing them on in a form he can view.
  8. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Ah:)
    My mistake, read your first post and it seemed to indicate that having HD content for your boss was the primary incentive not just to let him and his missus have the latest ep of their favorite US show:)
  9. James B
    James B
    Jul 29, 2004
    That's fair enough then, still might be quicked to download the SD versions and burn them to DVD, rather than re-encoding.
  10. jamesr
    jamesr
    yep, probably not being clear enough on the initial question!
    anyway, i gave it a go and the software is pretty impressive in its simplicity and ease of use if anyone else wants to do it.
