Question Converting old VHS to DVD
davidrichards27
Hi Guys
Not sure if this is the right place to post this?
I am looking for the most cost effective (cheap) method to connect my old VHS recorder to my laptop to transfer some old tapes to digital.
The VHS only has a scart output and I wondered if there is a simple Scart to USB cable available?
I usually shop on Amazon so if anyone might be anyone be to point me to one in there I would be really grateful.
Techy stuff is not really my forte!!
Thanks in advance for any help you can offer!
David
mjcairney
Hi, with VHS being analogue and USB being digital, a simple cable cannot do the job but, go to Amazon and do a search for "DIGITNOW! Video Grabber Capture Card Transfer TV / Hi8 / VHS to DVD, VHS Digital Converter with Scart Adaptor and RCA Cable" which will do what you you are looking for. At £23.99 it's a pretty well priced solution.
Seb Briggs
As above you may well try the cheaper DIGITNOW version, and with Amazon if it doesnt work then just return it and try the AverMedia one.
I only recommended the Avermedia as used their products before but the DIGITNOW may well do the job just as well, the software bundled with Avermedia does allow editing as well but that may not be important to you
Amazon product
Paramount + UK launch: Halo, Star Trek and Beavis, and all the latest 4K + Movie/TV News
