converting mpg files to dvd for playback
Discussion in 'Blu-ray & DVD Players & Recorders' started by mick23, Jan 2, 2007.
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    hi all i downloaded a movie clip ,but it is in mpg format, so i can play it on pc monitor ok.
    but i would like to tranfer it to a dvd disk to watch using dvd player +telivision but do not know which software to use, i have nero but i cannot see if this writes mpg to dvd ??
    thanks all
  2. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    assuming your DVD player doesnt do DIVX or MPEG then the only way is to do a realtime recording on to a blank disc on the computer....as in record in DVD-Video format......so it'll take as long as whatever it is you are trying to record (hopefully a legal mpeg of whatever it is)......most programs can do this, i would imagine Nero can....
  3. kit1cat
    kit1cat
    Sep 4, 2002
    1,501
    Plymouth
    +97
    ConvertXtoDVD and Ultra video joiner will convert various media files to dvd format. Try a google search and download the trial versions.
  4. mick23
    mick23
    Mar 20, 2002
    801
    uk
    thanks all i downloaded software trial to convert mpg to dvd format, but have just realised my new pcs inbuilt cd/dvd drive only has the ability to play dvds but not record to dvd .
    tried convertng to cdr vidio format but this does not seem to work properly .
    thank you
  5. New Bloke
    New Bloke
    Oct 3, 2002
    334
    28
    Aberdeen
    +24
    Nero has a program called Nero Vision Express, it's a now frill program to convert Divx to DVD, works for me.
  6. lasitha
    lasitha
    Jan 26, 2004
    270
    London
    +3
    Try using VCD format. Power Producer can generate VCD format, but I haven't tried converting MPEG into VCD.
  7. aniki
    aniki
    Nov 27, 2006
    598
    +74
    If its mpeg 1 and the resolution is correct its already vcd ready and you should be able to burn it as such straight to cd with nero.
    If not, TMPGEnc. will process it to legal vcd ready format.
  8. mick23
    mick23
    Mar 20, 2002
    801
    uk
    thanks all i used nero vision express, this converted my mpeg file to vcd used cd-r cd disk all works ok on stand alone dvd player recorder and tv.
