converting mp3's to to cda or whatever the proper cd format is
Discussion in 'Desktop & Laptop Computers Forum' started by oxygenuk, Aug 17, 2005.
  1. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,644
    38
    +13
    Hi.
    just wondering what can i use to convert mp3's to cda, as not all cd players are mp3 compatible its cda that is required right?
    also what is ccd? ive seen clonecd can produce ccd and img files or something but dont know what they are.
    so in a few words. i need a mp3 convertor/burner that can convert it to a standard audio format on a cd like the songs are on in the shops on the cd's (which i think is cda?).
    thanks
  2. shezzy2k
    shezzy2k
    Aug 17, 2004
    492
    28
    +26
    Nero & Many other CD burning applications will do this...just use the Audio CD option.
  3. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,644
    38
    +13
    when ive burned audio before its put mp3's on cd tho?
    so what program do i need to use and wat steps do i take?
  4. KoThreads
    KoThreads
    Jan 18, 2005
    2,966
    +158
    Use Nero to do an audio cd, then drag the mp3's over and burn. Mine converts them that way.
  5. rdhir
    rdhir
    Jul 31, 2005
    471
    Glasgow
    +8
    Don't know what version of Nero you have, but at least with version 5.0 you had to buy a cheap add on (5USD) which would do the mp3 to audio conversion. Check on Nero's website. It was a royalty thing as I think Frauenhofer charge licensing for the patents or some such.
  6. shezzy2k
    shezzy2k
    Aug 17, 2004
    492
    28
    +26
    If that happened you probably burned the disc a a data CD.
    I'm using the latest version of Nero (6.6.0.16).
    It may be best for you to use Nero Express as it has a simpler interface...
    1- Fire up Nero Express
    2- Highlight the music icon which will open another menu.
    3- Click on "Audio CD" which will open the drag and drop window.
    4- Click "Add" which will open another explorer window.
    5- Browse and select your mp3 files.
    6- Click "Add" then finished which will close the window.
    7- Click "Next" which will take you to the burn dialog screen.
    8- Select your desired burn speed then click "Burn".
    :thumbsup:
  7. oxygenuk
    oxygenuk
    Sep 12, 2004
    1,644
    38
    +13
    does nero express come with nero reloaded package.
  8. KoThreads
    KoThreads
    Jan 18, 2005
    2,966
    +158
    V. 6016
    Express is in>start>all progs>nero>nero6
