Converting M4P format
Discussion in 'Headphones, Earphones & Portable Music' started by Agincourt, Oct 28, 2005.
  1. Agincourt
    Agincourt
    Sep 12, 2005
    97
    Somerset
    +3
    I tried downloading music using iTunes for the first time last night (6 free downloads from BT) but made the mistake of not checking what format they would be downloaded in first. Unfortunately M4P is no use to me as I can't play it on my DAP. Is there any way of converting these files to a more widely used format (MP3 or WAV would be great)? Or do I simply put it down to experience? :lease:
  2. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
    DBPoweramp
  3. Agincourt
    Agincourt
    Sep 12, 2005
    97
    Somerset
    +3
    Thank you for the extremely quick reply. I've just tried it and dbpoweramp doesn't seem to recognize the .M4P file as a music format. Any clues/suggestions?
  4. lukey
    lukey
    Have you downloaded mp4 video files instead of audio files from the new itunes website,??? Ive have checked itunes and they download mp4 and H.264 video files, audio files are in aac 128kbs. If youve downloaded a video file I dont think theres anyway to convert to audio. :confused:
  5. Uridium
    Uridium
    Jan 29, 2005
    14,434
    +1,855
    go back on to the DBPoweramp website and you can download the codec packs to convert whatever formats you need.
  6. mick's cat
    mick's cat
    Audio files from iTunes are in a DRM-encoded AAC format. I doubt whether DBPoweramp will even look at them.
    You'll need JHymn (google it) to unencode the files, but I don't think JHymn is working for iTunes 6 songs yet, so if you've used iTunes 6 you'll have to wait until JHymn's updated.
  7. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    Or use iTunes to burn a music CD, then re-rip to MP3.
  8. Agincourt
    Agincourt
    Sep 12, 2005
    97
    Somerset
    +3
    Thank you everyone for the great support. I'm looking at J Hymn now, but it's not looking too good. Guess I'll have to go down the CD route. Long winded but it'll teach me to check the preference settings first. At least it's only 6 tracks and I didn't have to pay for them.
  9. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    Checking preferences wont help. All downloads from iTunes are in m4p format - DRM'd AAC files.
  10. Agincourt
    Agincourt
    Sep 12, 2005
    97
    Somerset
    +3
    So does that mean I can't use downloaded music from iTunes if my DAP won't decode M4P or AAC formats? (without going through the burn to CD routine)
  11. mick's cat
    mick's cat
    I suspect you're getting mixed up with terms. I hope this clears things up for you. Shout if it doesn't.
    Music you *rip* from a CD using the program *iTunes*, can be ripped in whatever chosen format and settings you want (AAC, mp3, ALAC and so on). There is no DRM-encoding on these songs whatsoever, so can be used on any player, or any computer you want that is capable of doing so.
    On the other hand, songs you *download* from the *iTunes Music Store* are formatted as AAC (with DRM encoding). These would need to be converted with JHymn, or burnt to CD and re-ripped as above, before they can be played on players incapable of playing them in their original format.
  12. vtah236
    vtah236
    Jul 25, 2005
    89
    9
    I have done this with JHymn, but had to download the mp3 codec. Worked fine.
  13. pcdoc
    pcdoc
    Feb 11, 2003
    140
    +3
    I usually just play it in ITunes and have a recording program to record the wave channel, then just mp3 the resulting wav file. Only takes the time to play the song(s) through.
  14. Agincourt
    Agincourt
    Sep 12, 2005
    97
    Somerset
    +3
    Having spent a fair amount of the weekend struggling with this, I am fairly sure that neither JHymn nor BDPoweramp can convert the .M4P files that I downloaded from iTunes. Burning to CD and ripping back to MP3 seems to be the best route but is v slow. I don't think I will be paying for downloads from iTunes, somehow, although, since these were freebies, I can't really complain too much.
  15. Happytab
    Happytab
    Jan 10, 2005
    261
    Can anyone give me the web address for the Jhymns thingy - I have googled but can not find the little blighter. Thanks alot
  16. mick's cat
    mick's cat
