Converting dvr-ms
Discussion in 'Microsoft Windows' started by mmm, Apr 28, 2007.
  1. mmm
    mmm
    Dec 6, 2002
    98
    Kent
    Hello,
    I want to be able to convert dvr-ms to another format, say avi or wmv. I have tried a few utils (dvr2wmv) and cant get them to work.
    Does anyone know of a simple (automated would be even better) util that could convert the dvr-ms to another format? I appreciate the dvr-ms has really good quality - but i am not too worried about a slight decrease in picture quality.
    cheers,
    m.
  2. MacBurp
    MacBurp
    Aug 9, 2005
    262
    28
    +22
    You need the DVRMS Toolbox - converts to MPG and strips out commercials. Google will find it for you.
    regards,
    Paul
  3. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
  4. scrambler2
    scrambler2
    Dec 16, 2006
    39
    +6
    There is a registry fix that enables Windows Movie Maker to read DVR-MS. Then you can import in movie maker, put it on the timeline, and save it in a variety of Wmv quality. The Highest quality shows almost no quality reduction, but a huge saving in size.
    In order to modify the registry, you need to cut and paste the text below inside Notepad, then save the file as something.reg (make sure it does not save it as .txt.
    Then you simply double click the name.reg file, and it will update the registry for you.
    I got that fix from the green button forum, and it works like a charm
    Windows Registry Editor Version 5.00
    [HKEY_CLASSES_ROOT\CLSID\{083863F1-70DE-11d0-BD40-00A0C911CE86}\Instance\{A4F9C3BA-A68F-4942-8152-B783CF89193F}]
    "CLSID"="{A4F9C3BA-A68F-4942-8152-B783CF89193F}"
    "FilterData"=hex:02,00,00,00,00,00,20,00,04,00,00,00,00,00,00,00,30,70,69,33,\
    00,00,00,00,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,30,74,79,33,00,\
    00,00,00,b0,00,00,00,c0,00,00,00,31,70,69,33,00,00,00,00,00,00,00,00,01,00,\
    00,00,00,00,00,00,00,00,00,00,30,74,79,33,00,00,00,00,d0,00,00,00,c0,00,00,\
    00,32,70,69,33,08,00,00,00,00,00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,\
    30,74,79,33,00,00,00,00,b0,00,00,00,c0,00,00,00,33,70,69,33,08,00,00,00,00,\
    00,00,00,01,00,00,00,00,00,00,00,00,00,00,00,30,74,79,33,00,00,00,00,d0,00,\
    00,00,c0,00,00,00,76,69,64,73,00,00,10,00,80,00,00,aa,00,38,9b,71,00,00,00,\
    00,00,00,00,00,00,00,00,00,00,00,00,00,61,75,64,73,00,00,10,00,80,00,00,aa,\
    00,38,9b,71
    "FriendlyName"="WMT MSDVR 2 Dexter Filter"
    [HKEY_CLASSES_ROOT\CLSID\{A4F9C3BA-A68F-4942-8152-B783CF89193F}]
    @="MSDVR"
    [HKEY_CLASSES_ROOT\CLSID\{A4F9C3BA-A68F-4942-8152-B783CF89193F}\InprocServer32]
    "ThreadingModel"="Both"
    @="C:\\Program Files\\Movie Maker\\wmm2dvr.dll"
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MM20\MSDVR]
    "MSDVRMinimumVersion"=hex:43,21,00,26,05,00,05,00
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MM20\MSDVR\MSDVRExtensions]
    "dvr-ms"=""
    "ms-dvr"=""
  5. db298
    db298
    Jun 8, 2004
    110
    +7
    Video Re-Do is an excellent app for editing DVR-MS shows, and then saving them out as MPG. Then you can use something like AutoGK for archiving, or any of the other many video convertors.
  6. mmm
    mmm
    Dec 6, 2002
    98
    Kent
    thanks for your replies everyone.
    I shall try the registry and utils asap...
    its a shame that MCE cant record in another format !! would save all this hassle.
    regards
    m
  7. alfaevans
    alfaevans
    Sep 15, 2006
    121
    +5
    don't forget dCut!
  8. mmm
    mmm
    Dec 6, 2002
    98
    Kent
    Tried the registry update - no joy - open up movie maker and try to open/import dvr-ms with no joy - keeps complaining that it doesnt recognise the format.
  9. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    It appears that this fix simply doesn't work for some folks. Do you have the file WMM2DVR.DLL in C:\Program Files\Movie Maker?
    Movie Maker in Vista does accept DVR-MS files as input.
  10. mmm
    mmm
    Dec 6, 2002
    98
    Kent
    just searched - do not have the file WMM2DVR.DLL anywhere...
    could i just "get a copy" and put it in the movie maker directory ??
    m
  11. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    I would guess that you have missed out on some update & it may not be as easy as just copying over & the file.
    There is a very good article by Stephen Toub of Microsoft that details converting DVR-MS to WMV in great detail with a sample application http://msdn2.microsoft.com/en-us/library/ms977847.aspx
  12. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
    Microsoft use this format because it provides the ability to use the trick play features (pause/rewind Live TV etc.). The open source MCE alternative Media Portal uses dvr-ms format files for just the same reason.
  13. scrambler2
    scrambler2
    Dec 16, 2006
    39
    +6
    mmm, what version of windows movie maker and XP do you have?
    I have XP service pack2, and Moviemaker 2.1.4026, and I have the Dll
    If you do not have the latest version of moviemaker, try downloading it from the MS site, and see if you have the dll then
  14. kolabere
    kolabere
    Feb 8, 2005
    419
    +7
    I too have XP service pack2, Moviemaker 2.1.4026, and I have the Dll
    But, the registry hack still hasn't enabled the importing of DVR.MS files by Moviemaker 2. :confused:
  15. mmm
    mmm
    Dec 6, 2002
    98
    Kent
    well I think I understand why I didnt have the dll - cos i tried it on a xp home pc...not a mce2005.
    checked the mce2005 pc that i have and the dll is there. so i did the registry hack and still no joy.
    have all the udpates/versions etc, but still no work.
    any ideas ?
  16. scrambler2
    scrambler2
    Dec 16, 2006
    39
    +6
    What exact error message are you getting when you try to open the DVR-MS file?
    I am attaching the actual .reg file I used in case the copy paste introduced an error. The file extension must be changed from .txt to .reg
  17. kolabere
    kolabere
    Feb 8, 2005
    419
    +7
    Sorry to take so long to reply. The error message I get is attached.
    I have also double checked all relevant reg entries and they are correct.
  18. timb64
    timb64
    Jul 6, 2006
    81
    Spent several hours at weekend trying to convert recorded files into mpegs for transfer onto dvd but always ended up with a really bad lip sinc problem on the finished article, to the extent of being unwatchable-any suggestions?
  19. scrambler2
    scrambler2
    Dec 16, 2006
    39
    +6
  20. scrambler2
    scrambler2
    Dec 16, 2006
    39
    +6
    Timb64,
    It all depends on what you use for the conversion and which decoders are on your machine.
    If you cannot use a better decoder / encoder, free editing application like Virtualdub, will let you change the sync between Audio and video.
  21. kolabere
    kolabere
    Feb 8, 2005
    419
    +7
    scrambler, sorry to take so long to get back, but I've been away.
    I ran the check and can confirm that the codec is Intervideo 5.0.11.768 - standard with the Sony VGX-XL100.
    Does this shed anylight on the problem?
  22. Spies
    Spies
    Aug 8, 2004
    298
    +10
    VideoReDo is the absolute best solution here.
