Converting colour to B&W in photoshop
Discussion in 'Photography Forums' started by SanPedro, May 5, 2005.
  1. SanPedro
    SanPedro
    Jan 11, 2001
    4,527
    +511
    Somebody posted a link once to some filters that gave really good results converting colour pics to black and white images in Photoshop.
    Anybody....?
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    Not sure what you are after Chris. Just suck out all the saturation. Alternatively copy the green channel into all all three colour channels. This is similar to how B/W film works.
    If you want sepia or other colourisation then just color correct your triple green channel image ( you could try red instead but forget about blue)
  3. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
  4. Mr.D
    Mr.D
    Jul 14, 2000
    11,165
    +1,202
    That method is pretty much what I've described. Copy a single channel into the other channels to give you a monochrome image ( red and green like I said avoid blue) and then you can mix percentages between the red channel only version and green channel only version. The demystified explanation of "replicating how b/w film behaves" ie simulating black and white negatives differing degrees of sensitivity to red green and blue light.
    (You can also try maxing and mining the versions together rather than a mix)
    There are not that many ways of making a colour photograph simulate a black and white one regardless of overly convoluted claims.
    Hate it when simple image manipulation processes get mystified , I regularly have to tell people in the industry off about this.
  5. DJW
    DJW
    Aug 29, 2002
    1,062
    16
