Complete Novice
Is it possible to buy something that you plug into your hi-fi so that you can recieve digital radio?
Complete Novice said:Is it possible to buy something that you plug into your hi-fi so that you can recieve digital radio?![]()
smcgirr said:You have the option of the tuners that have been listed above but there are other options available to you.
Genus do a device, the DU-1 which it describes as a DAB upgrade for hifi's. It plugs into hi-fi separates, micro systems, 5.1 surround sound systems or anything else with an AUX IN or an SP/DIF IN. basically all it is is a DAB reciever with line out but its a sexy looking device.
Alterante options are why not get a standard DAB radio and using the line out, plug it into a hifi input? The Perstel BlueNote is one of the cheapest DAB's around at the moment and you can take a cable from the headphone socket into your hifi input. Not the best quality sound and no remote control but it does that job relatively cheaply!
