Converters - pointless uprade?
Discussion in 'Cables & Switches' started by 'dozer, Aug 20, 2004.
  1. 'dozer
    'dozer
    Aug 20, 2004
    3
    4
    Hi, first post so be nice.
    I have heard about RGB to component converters (Ithink Keene electronics do one). I have a Panny TX32PD30 and want to know if there is any merit from using one of these to convert the signal from say a DVD or freeview box?
    Cheers! :thumbsup:
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,136
    2
    +3,587
    It depends how much £85 odd means to you. My dad uses one on a Pace twin and is thrilled with the results on his 36PD30 if that is any help.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    Pannys Acuity chassis is notoriuosly bad at RGBS so it may be a worthwhile upgrade, better upgrade might be a DVD player with component output also look at JS technology converters!
  4. 'dozer
    'dozer
    Aug 20, 2004
    3
    4
    Thanks!
    The DVD will definitely be upgraded soon. My biggest gripe with my current set-up is when watching freeview. Any fast panning motion produces noticable noise - mainly in the background. The main reason for looking at signal converters is to try and reduce this.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    try stteing FV to S-video if you can, might need to use AV2 on TV
