Converter PDF
Discussion in 'Computer Software & Operating Systems' started by peanutdemon69, Jan 11, 2012.
  1. peanutdemon69
    peanutdemon69
    Aug 12, 2007
    197
    Troon
    +12
    Hello guys i am looking to see if this possible i want to convert a PDF file into a word doc can i get software out there to do this.Been looking but not a lot out there
  2. Singh400
    Singh400
    Feb 21, 2006
    17,858
    Earth
    +3,370
    PDF to Word Converter
    It's an online service. It works most of the time for me. It isn't perfect though.
  3. FireKracker
    FireKracker
    Jan 10, 2008
    627
    Derbyshire
    +98
    There are lots of utilities out there that will do it, I'm guessing your looking for a 'free' alternative?
    Online utilities include: http://www.pdfonline.com/pdf - word or http://www.freepdfconvert.com
    Additionally open the PDF, press
    • Ctrl+A (Selects the whole document),
    • press Ctrl+C (copies the selected content)
    • Open your word processor and press Ctrl+V (this pastes the selected content)
    Things to consider:
    The conversion depends on a couple of factors, the security and privacy setup (if any) on the PDF and the quality of the conversion. E.g if the PDF is a basic text document conversion should be straightforward, however if the document contains numerous boxes, pictures, etc the result may not be usable.
    Hope that helps
  4. peanutdemon69
    peanutdemon69
    Aug 12, 2007
    197
    Troon
    +12
  5. imightbewrong
    imightbewrong
    Dec 6, 2005
    53,046
    167
    Romford-ish
    +33,566
    copy -> paste ? :)
    depending on required accuracy and frequency
  6. imightbewrong
    imightbewrong
    Dec 6, 2005
    53,046
    167
    Romford-ish
    +33,566
