convergence on toshiba 36zp48
Discussion in 'TVs' started by me@home, Dec 16, 2004.
  1. me@home
    me@home
    just purchased a tosh 36zp48.very dissapointed with the picture,the colour convergence is all over the place.is there any way i can resolve this???? :lease:
  2. DRGL
    DRGL
    Mar 30, 2004
    746
    Shropshire,UK
    any pictures? if it's that bad i would get them to replace it ;) Don't see why you should have to risk messing things up in the service menu.
  3. me@home
    me@home
    unfortunately i have no pictures! Most articles on the screen have a red edge on the top.Any white type has red and green borders,the tv listing page on sky,has edges around the black type,and the yellow background is approx 2mm away from the type sideways
  4. DRGL
    DRGL
    Mar 30, 2004
    746
    Shropshire,UK
    Most TV's of that size will have some mis convergence,i guess it depends on what you class as acceptable? I wouldn't like it by the sounds of it!
  5. Rushy
    Rushy
    Jun 26, 2002
    99
    11
    Manchester
    +16
    Convergence is nigh on perfect on my ZP48, sounds like you should get yours fixed/replaced.
