Convergence menu on 40who8b, how?
Discussion in 'General TV Discussions Forum' started by raigraphixs, Oct 29, 2001.
  1. raigraphixs
    raigraphixs
    Jul 11, 2001
    63,115
    +23,987
    Hi Guys,
    I have just brought a 40who8b and in the book it shows a convergence menu under blue screen, but on the tv it is not there?, how do i get to it, or the engineers menu.
    rai
    please help, so i can check alignments
  2. bh
    bh
    Jul 14, 2000
    397
    Lost (no GPS here)!
    Rai,
    If your set is like the O3 model, you'll find that the convergence menu is at the bottom of the menu that is the right. You'll see an arrow which does not have any text around it. If you press on the arrow it will take you to the normal convergence setup.
    Sorry is this sounds more complicated than it is.
  3. raigraphixs
    raigraphixs
    Jul 11, 2001
    63,115
    +23,987
    Thanks, i have a look tonight when i get home. But when going to the 'blue screen' option and going down, it takes you back up to the top of the menu list does'nt it?.
    Anyway, check back tomorrow, incase i need more info.
    thanks
    rai
  4. raigraphixs
    raigraphixs
    Jul 11, 2001
    63,115
    +23,987
    I managed to get the menu up, it was because i did not have the RF aerial in, for some reason some menus dont come up for different combinations. Any way i lined up the arrows on the convergence menu, which is a bit hit and miss, as there seems to be slight halos.
    Anyway the picture is top notch, but i was thinking if i should just get an engineer in to check the setup, can i call in one for calibrating the set further anyway?. Has anyone done this?
    thanks
    rai
  5. bh
    bh
    Jul 14, 2000
    397
    Lost (no GPS here)!
    You have mail ....
