Convergence issue sony 55" rp
Discussion in 'General TV Discussions Forum' started by jedi-knight, May 6, 2007.
  1. jedi-knight
    jedi-knight
    Nov 2, 2004
    950
    Llanelli
    +16
    I have the 55" sony but I have noticed that the convergence looks slightly out by say a pixel or two, when up close to the screen easily noticeable but from 8-10ft I don't see it.
    when displaying white the red bleeds to the top and right and the blue bleeds to the bottom and left.[​IMG]
    but then when displaying black or yellow the red bleeds bottom and left with the blue bleeding top and right.[​IMG]
    If this is a convergence error, will setting the red and blue perfect for whites make the blacks even worse ?
    If it can be corrected in the service menu how can I set it as I don't have a clue what anything means in the service menu ?
    cheers.:)
  2. Paulherb
    Paulherb
    Jan 5, 2002
    253
    +3
    I'm in the same boat as you and have posted a thread yesterday(no replies yet).
    I can get into the service menu but I need a bit of guidance from there as there are alot of options.
    Come on you experts share the love.
    Paulh.
  3. Tarbat
    Tarbat
    Oct 15, 2003
    2,590
    Easter Ross, Scotland
    +302
    I'd have to do what you can do - search the forum. I can't remember what the field names are of the top of my head. Try a search on "convergence" and trawl through the results.
  4. Tarbat
    Tarbat
    Oct 15, 2003
    2,590
    +302
    Found it
    Go to the Service Menu / Panel Menu / 1 TG submenu
    Items 1, 2, 3 are the Horizontal Convergence Adjustments for R, G, B
    (HSIFTR, HSFTG, HSFTB)
    Items 25, 26, 27 are the Vertical Convergence Adjustments for R, G, B
    (VSFT_R, VSFT_G, VSFT_B)
  5. jedi-knight
    jedi-knight
    Nov 2, 2004
    950
    Llanelli
    +16
    sorry Tarbat but like I said I dont have a clue of the menu system cannot see any of these options, how do I get to the panel menu and then the 1 tg submenu ?
    thanks.
  6. Tarbat
    Tarbat
    Oct 15, 2003
    2,590
    +302
    Again, I can't remember, I'd have to search these forums. Try looking in the SXRD settings thread, or try a search on "service menu".
  7. Tarbat
    Tarbat
    Oct 15, 2003
    2,590
    +302
  8. jedi-knight
    jedi-knight
    Nov 2, 2004
    950
    Llanelli
    +16
    I went through the thread before to get the service menu instructions, it said the same thing :
    panel
    1tg
    vsftr
    but I do not see any of those options in the service mode on my tv - where does it say panel ? 1 tg or even vsftr ??
    :confused:
    cheers tarbat.
  9. Tarbat
    Tarbat
    Oct 15, 2003
    2,590
    +302
    Should be straightforward. Go into the service, use the jump key (to the right of 0 on the remote) to get to the PANEL menu, then use 2 & 5 to navigate to the 1TG section, then use 1 & 4 to find the right parameter.
    [​IMG]
  10. jedi-knight
    jedi-knight
    Nov 2, 2004
    950
    Llanelli
    +16
    Cheers, tarbat. Done.
    :thumbsup: :thumbsup:
  11. jedi-knight
    jedi-knight
    Nov 2, 2004
    950
    Llanelli
    +16
    A little bit of a problem with this, where 1080p picture has perfect convergence, but as soon as i go back to a lower 480 resolution it still shows the convergence bleeding, why ??:confused:
  12. Tarbat
    Tarbat
    Oct 15, 2003
    2,590
    +302
    What type of input is that - SCART, Component, ?? Doesn't sound like a convergence problem.
  13. jedi-knight
    jedi-knight
    Nov 2, 2004
    950
    Llanelli
    +16
    1080p via hdmi = perfect
    576p via hdmi = still convergence issue but not as bad.
    sky via scart = still convergence issue but not as bad.
    is this normal ?
