Convergance help on a Toshiba 40PW03B
Discussion in 'TVs' started by dealstokie, Jun 2, 2005.
  1. dealstokie
    dealstokie
    May 16, 2005
    338
    Anyone know how to sort out the convergance on this rear pro?
    Can you do it manually? or automaticly? can you do it on the actual coloured bulbs inside the set?
    Help please !!!!
  2. JayCee
    JayCee
    Jan 20, 2004
    20,326
    Lanarkshire
    +1,953
    It uses 3 crts, not "coloured bulbs"
  3. dealstokie
    dealstokie
    May 16, 2005
    338
    Forgive me I'm mew, they look like 3 coloured bulbs.
  4. avanzato
    avanzato
    Jan 21, 2003
    1,881
    Norfolk
    +61
    You can do the convergance in the user menu or in the service menu I did mine in the service menu last night after moving the TV back into my room. You can break the TV by using the service menu if you change the wrong settings. I can let you know the buttons to press if you understand that.
