controlling volume on Denon 2805
kev777
Hi all,
I'm trying to control the amp by using either my:
Pioneer PDP 506 XDE
or
Sky + control.
Now there is the SR connection Pio uses to connect devices together but I really want to be able to control the amp's volume using my Pio or Sky + remote control.
I've done a search and found a few threads but so far nothing works.
Can anyone help?
Thanks,
Kev.
Ru55
Ello mate
I have a list some where of codes and actions to get ya sky+ remote to opp your amp. Ill find it out and post on here for ya!
It ops my yamaha Z9 and my mates Denon no probs, though only does simple actions like volume, on and off etc....
Later
kev777
Thanks, very much appreciated if you can.. have done a search here already and tried the codes but none of them work...
Ru55
Yea I went through a load of crapy codes I found on the net and they didnt work.
The ones I have do for some reason, though not saying will deff work with you mate, but its worth a shot!
Spielberg, Shyamalan, Aronofsky, Chazelle, Eddie Murphy and Mel Gibson - all the latest movies
