Controlling Sky Plus with A Standard Sky Remote
Discussion in 'Sky Digital TV Forum' started by Just_Dabbling, Feb 21, 2003.
  1. Just_Dabbling
    Just_Dabbling
    Can anyone confirm if it is possible to control a sky+ box basic functions using a standard sky digital remote.
    I am looking at getting a sky+ box and I already have a IR-RF transmitter to change channels from the bedroom.
    At present I use an old one for all jobbie but it would be nice after having it installed to the old sky remote upstairs (until I can convince the missus we need a second subscription).
  2. boltoa
    boltoa
    Oct 10, 2002
    917
    2
    46
    Nottingham
    +103
    Why not get a proper TVLink from Sky? The original remote can control a very limited number of functions on Sky+ (there is a procedure on some website that I can't find right now).
    This place used to do kits with amplifier, sky+ remote, and tv link, but doesn't appear to be on their website anymore. You can probably phone to get a deal tho.
    Andrew
  3. boltoa
    boltoa
    Oct 10, 2002
    917
    2
    46
    Nottingham
    +103
    Ah, found the Sky to Sky+ remote procedure here.
    Hope that helps. It is only the channel up/down buttons that work tho :(.
    Andrew
  4. bobbles
    bobbles
    You can buy sky+ remotes from Maplins, but you might be better off getting a cheap programmable remote
  5. Paul D
    Paul D
    Dec 27, 2000
    2,708
    Manchester
    +515
    You get an extra Sky+ remote cheap here when they get stock.
    Sky+ remote click here!
    £23.50 inc Vat
    P&P extra though...
