Controlling sky digibox with PDA
Discussion in 'Home Cinema Control & Remote Controls' started by jamiesneddon, Dec 27, 2004.
  1. jamiesneddon
    jamiesneddon
    I have started using my Dell Axim X5 with the winPDA software to control all my kit, Its working a dream so far apart from changing sky channels. I have them programmed in but the sky digibox is receiving three key presses - ie to change to sky one (106) my digibox is receiving 111 000 666. Is there a way to sort this ? I have tried changing the delay settings in prontoedit between 0 and 1 second with no luck.
    Would it help if I purchased an infrared extender for my PDA?
    Any replies would be helpful as I dont want to spend £30 on an ir extender to find out this doesnt work.
