Controlling Room Lights With Google Assistant
buzza_2004
I currently have two google homes in the house and use it to control some Sonoff plugs for lighting.
I would like to investigate being able to turn the main room lights on / off and was looking some some advice on where to start.
I have two switches in the room (1 being a dimmer) and I do not want these replaced / removed. I don't want to use smart "bulbs" either as there are 12 LED G9's.
Is there anything i can add in my lighting circuit that will enable me to do it fairly easily, like a sonoff switch? I would prefer a WiFi connected device but if that's not available the could look at zwave / zigbee. I could look at setting up home assistant on my NAS too.
The Aeotec dimmer looks good but not sure it will fit behind my current switches. Do they work on a 2way lighting system?
Thanks.
D
Deleted member 24354
You could use a Fibaro dimmer
Z-Wave Fibaro Universal Dimmer 2 250W
which are 2/3 wire modules and will work on 2 way lighting.
I cannot help with Sonoff as i do not believe that their products are safe to use. They claim that this is a Declaration of Conformity for their products:
https://www.itead.cc/wiki/images/f/f7/CE_Certificate_for_Sonoff_Series.pdf
Which it most definitely is not. This also makes their CE marking invalid. Hence my reluctance to either recommend or assist with any of their product lines.
