Controlling Hidden Equipment
Discussion in 'Projectors, Screens & Video Processors' started by Amelia, Jul 19, 2002.
  1. Amelia
    Amelia
    I want to have my DVD Player, Amp etc all hidden, which should make the room look great . . . but . . . how do I Control everything.
    Anyone got any ideas?
    Regards
    Amelia
  2. Messiah
    Messiah
    Apr 22, 2002
    7,620
    +338
    Use a remote extender. Take a look here
  3. tomthx
    tomthx
    Jul 16, 2002
    Sydney, Australia
    Amelia,
    I have all of my gear in a cabinet that is under the screen and behind closed doors, it contains the Center speaker as well. I designed it and had a pine place build it for me. I use a Avico's IR Extender One Zone in Four Out (HCH14, $60), a IR Extender IR Receiver (HIR7, $12) and a couple of IR Extender Double Emmitter's (HIR3, $15). It all works well for me. Info can be found here, select Audio and then General.
    Any electronic shop should be able to get this stuff in, if not send me an email and I'll see what I can find for you here. Hope this helps.
    Tom.
    BTW, I got the same deal you did on the AE100 from Clivepeeter but mine will be delivered straight from the Panasonic Warehouse in Sydney on the 1st of August.
  4. Amelia
    Amelia
    Hi Messiah,
    Wow, it looks like I have a lot to learn about all this stuff. Thanks for the link !!!!
    Hi Tom,
    Thanks for the links and info. Have you decided how you are going to mount your PJ. I am pretty sure you will be happy with it. Mine is put away now and I the room being renovated :D
    Best Regards
    Amelia
