Controlling DAB
Discussion in 'Music Streamers' started by edward, Jul 4, 2005.
  1. edward
    edward
    Apr 2, 2003
    858
    32
    Reading
    +26
    Now what have I done?
    I cleared my DAB memory and did another scan for stations. It stopped at 100 and put up BBC 3/Classic. I saved it on key 3 OK.
    I then tried to use the cursor arrows surrounding the OK button to find more stations but instead it indicates it is seeing them as balance controls of various kinds. I pressed the DAB input selection and held it - no subsequent difference.
    It was working fine when I first set up DAB but then a managed to screw up the stations assigned to some keys so I thought I'd start again. I don't recall this alternate function on the cursor keys last time.
    What have I overlooked?
  2. Welly123
    Welly123
    May 18, 2002
    248
    Hi Edward,
    I think you've probably set the "cursor assignment" back to default. Check-out page 39 of the user-guide, it gives options for setting the cursor keys to various modes... including FM & DAB control.
    Regards
  3. edward
    edward
    Apr 2, 2003
    858
    32
    Reading
    +26
    Many thanks, Russell, works a treat!!
