Hello fellow Arcamites
I have added a T61 to my system and it seems to use the same control codes as my AVR300 so I can not turn them on/off independently.
I can not change the AVR300 to RC-5 19 as my A32 is using that (as it clashed with the AVR300 too).
One way I can see is to use the remote power trigger from either the A32 but maybe the AVR300 so it comes on with it anyway but that is not a good solution as it may turn on with the trigger and off with the ir code.
Has any one any ideas how to get around this?
Thanks.
Ian.
Thanks.
Ian.
