Controlling an amp from another room
Discussion in 'Home Cinema Control & Remote Controls' started by Bert Coules, Sep 14, 2003.
  1. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,268
    +158
    Forgive the extremely basic question, but I've no experience at all in this area...
    I want to be able to control the volume of my Denon amp from another room - specifically, the bathroom. I'm planning to install a couple of small speakers in said bathroom, fed from the secondary output of the Denon, and though I don't want to go down the full home-automation route, I would like to have local control over the volume.
    I reckon that with careful use a basic learning remote will be safe enough in the bathroom; but is there a simple way of routing the remote signal to the site of the amp? If so, is the sending device, whatever it is, of a form which I can mount unobtrusively in the walls?
    Alternatively, is there any way of permanently hard-wiring a volume control between the amp output and the speakers?
    Many thanks in advance.
    Bert
    www.bertcoules.co.uk
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,350
    Rainham Essex
    +2,441
    From what I know you have 2 options (probably more though!).
    1. get a remote that works with an RF receiver. Set the remote to transmit Rf and set up the RF receiver to point at the Denon.
    Pro: No other device other than the remote required in the bathroom.
    Con: only on expensive remotes such as Pronto Pro/ Marantz RC9200
    2. Get a remote extender from somewhere like www.maplin.co.uk
    Pro: cheaper than above remotes.
    Con: Need to install in wall etc. Needs lone of sight from remote.
    Mark.
  3. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,268
    +158
    Mark,
    Thanks for the thoughts.
    I do have (and use) a Pronto Pro, but I wouldn't be over-anxious to play with it near a bath full of water. I'll look into the remote extender.
    Edited to add:
    I've just come across this...
    http://www.lektropacks.co.uk/product/technical.asp?dept_id=111&sku=154&Hash=154
    ...a local stereo volume control which can be wall-mounted in a standard double-gang box. There's no information in the spec on its suitability for bathrooms, but it's obviously worth investigating. The single knob looks a bit lost in the middle of the double-socket-sized faceplate, but doubtless there are ways round that.
    Bert
