control receiver and dvd player in unit with closed wooden door - I'm confused?
Discussion in 'Home Cinema Control & Remote Controls' started by M6TT F, Feb 26, 2014.
  1. M6TT F
    M6TT F
    Aug 14, 2006
    191
    macclesfield, cheshire
    +5
  2. logiciel
    logiciel
    Feb 2, 2008
    53,138
    UK
    +5,778
    It doesn't say you need the extender cable regardless.
    Only if you want the extenders do you need the extender cable.
  3. M6TT F
    M6TT F
    Aug 14, 2006
    191
    +5
    sorry, i wasn't clear. it says if your kit is in a locked/closed cupboard you need the extender cable?
  4. logiciel
    logiciel
    Feb 2, 2008
    53,138
    UK
    +5,778
    That's OK - you were fine - it's tucked away in the FAQs!
    If your equipment will "see" the second unit then all will be well and nothing else will be needed.
    You might like to consider the Powermid 300 XTRA instead.
    It's a more recent model that works on batteries.
