Control pad woe
Discussion in 'Playstation Forums' started by gers1978, Jan 14, 2008.
  1. gers1978
    gers1978
    Aug 2, 2006
    1,581
    Glasgow
    +173
    For the love of god I wish Sony would update the firmware to add a feature that turns off the pad after x mins non-use. The 360 does it, and as I was used to it for months, I keep forgetting the PS3 doesn't, so when I sit down to play I find the pad has flat!!!
    Couple that with the fact the charging lead is only about 1m long, and I can't play till the bloody thing is charged up again!
    Argghhhh!
  2. Workshed
    Workshed
    Jan 28, 2007
    1,653
    Radstock, Bath
    +146
    i know it sounds crazy but why dont you just turn the console off when you're not using it? Personally I've never seen it as a problem that the controllers dont turn off on their own.
  3. Billy Hunt
    Billy Hunt
    Jun 29, 2002
    1,185
    Worksop
    +98
    Or press the PS button and select turn off controller :confused:
    When I saw the title I thought your pad had fell apart or something :rolleyes:
  4. Bomer
    Bomer
    Dec 2, 2007
    266
    +19
    lol, it would be a nice feature tbh, as I usually play music and leave the pad on incase I want to skip etc, but then I venture off or friends come round and I forget to turn the control off while the music is playing, a 15min timeout would be nice tbh
    No biggie though :p
  5. Workshed
    Workshed
    Jan 28, 2007
    1,653
    Radstock, Bath
    +146
    If you get the bluetooth remote control that does exactly what you're saying ;)
  6. Bomer
    Bomer
    Dec 2, 2007
    266
    +19
    Ah ha! Thanks for that :) May have to invest in one now!
  7. gers1978
    gers1978
    Aug 2, 2006
    1,581
    Glasgow
    +173
    Because I like to run [email protected]
  8. Mark Botwright
    Mark Botwright
    Moderator & Reviewer
    Nov 3, 2006
    8,206
    +1,341
    As you all should be. ;) (only if you're in the AVF team though)
  9. gers1978
    gers1978
    Aug 2, 2006
    1,581
    Glasgow
    +173
    I am.
    Problem is though, since I have a replacement PS3, my own individual stats are "lost" - it seems you can't tie your existing stats to your new console.
  10. Mark Botwright
    Mark Botwright
    Nov 3, 2006
    8,206
    +1,341
    At least it gives me a chance to catch your old score now though. ;)
  11. tabs
    tabs
    Apr 3, 2005
    1,974
    warks
    +129
    if you have a pc thats on most of the time .. just plug it into that, saves keeping ya ps3 on just to charge the pad
  12. gibbers
    gibbers
    May 8, 2007
    549
    28
    +38
    I leave my ps3 on for ages doing nothing and my control pads still last for ages so its not an issue for me, plus i have 2 so when one is in use i charge the other one
  13. 6950rpm
    6950rpm
    May 26, 2006
    149
    +10
    Get yourself one of these...
    [​IMG]
    and I plug it in to one of these...
    [​IMG]
    and have it sitting on a little table next to the sofa. Al rather discrete and I never have to worry about the charge level in the controller.
