Eggman
I'm installing a JVX X5900 into a projector lift, and have a grand view screen. Im confused about the best configuration with the 12V triggers. I believe the lift has a 12v in and 12v out so the logical thing to do is to put the projectors 12V trigger into the lift and then the lift 12v out to the screen, so when you turn the projector on the lift and screen both come down. However, will I be able to turn the projector on with the IR remote when its hidden in the ceiling!? Can you turn on the projector through HDMI from the AVR?
Thanks for any help
Andrew
Thanks for any help
Andrew
