Hi folks, I.have this side fan:https://www.amazon.co.uk/Aerocool-Silent-Master-Sleeve-Bearing/dp/B005JRZIO2
Connected via 4PIN molex, in a gigabyte sumo omega case, which had a fan control switch. However, the switch doesn't slow or speed up the fans. Now there are two other connections on this fan, both 2 pin, one is red and black wire, the other blue and black. So which do I connect and to where to enable the switch to work?
— As an Amazon Associate, AVForums earns from qualifying purchases —
