Control compatibility between Crestron & Loewe
Discussion in 'Home Cinema Buying & Building' started by bba1, Nov 5, 2005.
  1. bba1
    bba1
    Due to the annoyance of Loewe's AV selection being on a toggle switch, you cannot access...say AV2 without pressing more than 2 commands. Now, I know this can be overcome by programming the macro functions through a pronto, but it becomes even more difficult when using a Crestron wireless web tab.
    I need to know...
    1. If there is an easy way to do this (wood for the tree's)
    2. If there is a range of screens 26"-37" min that have direct access to the AV inputs, have HDMI input and will play HDTV at 720p.
    3. If Loewe are developing any of their screen with RS232.
    Any info will be most helpful.
  2. Vis Man
    Vis Man
    Feb 22, 2001
    207
    UK
    +10
    Have you tried the ir driver from the Crestron data base.
    Sometimes the codes from different models work.
    The Planus driver has individual input selection.
  3. bjp
    bjp
    Dec 11, 2005
    148
    +6
    There is no rs-232 screens on the way, but i can have look for discrete codes 4 you.
