mickymcd
Established Member
Howdee ive got a grandish to spend max on a plasma ones ive seen is a hyundai here are the specs
Visible Diagona:42"
Display Area (mm):932.9(H) x 532.8 (V) [36.72"(H) x 20.97"(V)]
Pixel pitch (mm):1.095 x 1.11
Aspect Ratio:16 : 9
Display colors:16.7M
Brightness (cd/u):1000
Contrast Ratio:3200 : 1
Viewing Angle
H/V) over 160
Resolution:852 X 480
Display Capability(DTV Ready):480p,576p,720p,1080i
Progressive Scan:Yes
Color Tone Control:Yes
ive seen a relysis here are the specs on this
Diagonal 42"
Resolution 852 x 480
Aspect Ratio 16:9
Brightness 1500 cd/m²
Pixel Pitch 1.08 mm
Contrast Ratio 10000:1
Colours 1 billion
Viewing angle 160°
Computer Resolution VGA, SVGA, XGA, SXGA
Computer Inputs RGB Analogue & DVI
Video Inputs Composite, S-Video, Component, SCART
Video Modes PAL, SECAM
Power Consumption 240W
Speakers Option
Dimensions 1028 x 625 x 107.4 mm
Weight 29kg
the relisys is £100 more but is it worth the extra £100?
Visible Diagona:42"
Aspect Ratio:16 : 9
Viewing Angle
Diagonal 42"
Aspect Ratio 16:9
Pixel Pitch 1.08 mm
Colours 1 billion
Viewing angle 160°
Speakers Option
Weight 29kg
