Contrast on a Viera
Discussion in 'Plasma TVs Forum' started by Steffche, Nov 15, 2004.
  1. Steffche
    Steffche
    I was playing around with DVE last night, and ended up having contrast wound all the way down to 9/100. I used to have it at 30....then I dropped it down to 25 a few days ago...and still noticed it was too high at times....and now im down to 9. Does anyone else have such a low contrast setting?
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,741
    London
    +1,075
    Mine's around 25% - and I thought that was low :eek:
  3. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,539
    London
    +467
    Does the Aus model have settings out of 100's ?
    The UK one does not, apart from a block indicator.
  4. Steffche
    Steffche
    Yep...all settings are out of 100.
    How did you arrive at your contrast settings???
  5. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,539
    London
    +467
    Uk ones are just a block bar.
    Have mine set to what appears to be about 35-40% on both contrast and brightness in Normal mode. Looks fine. ;)
  6. blindlemon
    blindlemon
    If your underlying contrast is too high then you can adjust the "sub-contrast" in the Service menus to give you more leeway on the user-controls.
    Initially I found that I was having to set the contrast in Cinema mode at less than 10% for evening viewing, but that for some programmes even 0% wasn't low enough, so I reduced the sub-contrast by 20. Now my main menu contrast bar setting ranges between around 25% and 50% depending on the source material.
  7. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,516
    Kent
    +830
    HAve you any contrast and brightness adjustments on your DVD player??? When set wrong these kill the output of your player before your plasma even has a chance to get the best setup. Worth a quick check anyway.
  8. Steffche
    Steffche
    No...there are no picture settings on my DVD player. Its the pioneer dv-344. oNly has options for cinema, standard and animation.
  9. brackenlamb
    brackenlamb
    Oct 14, 2003
    421
    how did you get into the service menu,
  10. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    blindlemon, brackenlamb et al.
    I know that I keep on but..........
    Get it calibrated! Since I had mine done I haven't needed to touch the settings regardless of source.
  11. NonPayingMember
    NonPayingMember
    Oct 18, 2002
    8,516
    Kent
    +830
    Steffe - those three modes will adjust contrast, colour and brightness so having it set on the wrong one could have an effect. Normal is likely the best but Cinema might be worth a try
  12. brackenlamb
    brackenlamb
    Oct 14, 2003
    421
    i know i know maybe one day i will but im gona have a small go myself with an avia disc ,as im already happy with the picture.
    I fi spend any more this year im gona be in trouble :rolleyes:
  13. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    Yeh, it gets to be an expensive hobby.Still, when the cash settles down........
    The biggest adjustment I saw Gordon make I don't think you can do.(and I wouldn't try)
    Via the service menu he individually adjusted red, blue and green to the correct temperature. He measured them individually on various white settings from a test page using a piece of kit pushed against the screen and linked to his PC.
    Red and green were closeish, but blue was way out! I know it shouldn't be on a new screen from the factory, but it was.
    And the overscan was huge.
    I should be on commission, but I'm not. Just trying to help.
