Continuing problems Studio9
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by TheHighlander, Jul 31, 2004.
  1. TheHighlander
    TheHighlander
    I've posted before but now have a few updates.
    The program will run through to produce to tape and to AVI but it won't produce to MPEG or DVD. Also as advised i've produced an AVI file and then re input that and tried rendering as a new project, this also stalls
    I've updated to DIRECTX9c and the latest drivers for graphics card and motherboard.
    Full system spec below...
    Any ideas what else to try?
    System Spec:
    Processor
    Model : AMD Athlon(tm) XP 3000+
    Speed : 2.16GHz
    Model Number : 3000 (estimated)
    Performance Rating : PR3136 (estimated)
    Type : Standard
    L2 On-board Cache : 512kB ECC Synchronous Write-Back (16-way, 64 byte line size)
    Mainboard
    Bus(es) : ISA AGP PCI USB FireWire/1394 i2c/SMBus
    MP Support : No
    MP APIC : No
    System BIOS : Phoenix Technologies, LTD 6.00 PG
    Mainboard : MICRO-STAR INTERNATIONAL CO., LTD MS-6570
    Total Memory : 1023MB DDR-SDRAM
    Chipset 1
    Model : Nvidia Corp nForce2 AGP Controller
    Front Side Bus Speed : 2x 166MHz (332MHz data rate)
    Total Memory : 1024MB DDR-SDRAM
    Memory Bus Speed : 2x 166MHz (332MHz data rate)
    Video System
    Monitor/Panel : Default Monitor
    Adapter : RADEON 9600 SERIES
    Adapter : RADEON 9600 SERIES - Secondary
    Physical Storage Devices
    Removable Drive : Floppy disk drive
    Hard Disk : ExcelStor Technology J680
    Hard Disk : IC35L120AVVA07-0
    CD-ROM/DVD : LITE-ON LTR-40125S
    CD-ROM/DVD : PIONEER DVD-RW DVR-106D
    Logical Storage Devices
    1.44MB 3.5" (A : N/A
    Hard Disk (C : 76.7GB (73.9GB, 96% Free) (NTFS)
    CD-ROM/DVD (D : N/A
    CD-ROM/DVD (E : N/A
    Video (F : 115.0GB (88.0GB, 76% Free) (NTFS)
    Peripherals
    Serial/Parallel Port(s) : 2 COM / 1 LPT
    USB Controller/Hub : Standard OpenHCD USB Host Controller
    USB Controller/Hub : Standard Enhanced PCI to USB Host Controller
    USB Controller/Hub : USB Root Hub
    USB Controller/Hub : USB 2.0 Root Hub
    FireWire/1394 Controller/Hub : OHCI Compliant IEEE 1394 Host Controller
    Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
    Mouse : PS/2 Compatible Mouse
    MultiMedia Device(s)
    Device : NVIDIA(R) nForce(TM) Audio Codec Interface
    Device : NVIDIA(R) nForce(TM) MCP Audio Processing Unit (Dolby(R) Digital)
    Device : Pinnacle AV/DV2
    Power Management
    AC Line Status : On-Line
    Operating System(s)
    Windows System : Microsoft Windows 2000 Professional (Win32 x86) 5.00.2195 (Service Pack 4)
    Network Services
    Adapter : NVIDIA nForce MCP Networking Controller
  2. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +149
    Yes, ULead Video Stidio 8 or other!
    Honestly, you're banging your head against the wall with Pinnacle.
    I and a lot of others on this forum gave up on Pinnacle at version 8.
    It's just not worth the hassle.
    Why they haven't fixed the stability issues with v9.0, God only knows. They're losing a lot of customers.
  3. laser
    laser
    Aug 1, 2004
    986
    Hartlepool
    +45
    I gave up with Studio 9 as it was too unstable and reverted back to the last update of Studio 8 which although it runs very slow compared to Studio 7, is at least very stable and does not crash.
    I can only suggest you uninstall and then reinstall but after reinstallation put the latest Studio 9 patch on. After you uninstall, delete the folders for Pinnacle in c:/Program Files and then reboot before you reinstall.
    Have you checked the Pinnacle site for known problems?
    If that doesn't work then I would probably consider looking for another video editing program, while not good news, I'd cut your losses as you could go round in corcles trying to get it to work.
    As a last measure you could format the HDD and start from scartch so your Windows registry is tidy and perform an install on a clean PC but you shouldn't have to do that.
    Iain
