Continuing Problem with reception
Discussion in 'Satellite TV, Sky TV & FreeSat' started by deezel, Dec 19, 2004.
  1. deezel
    deezel
    Oct 25, 2004
    322
    +7
    Have posted before regarding reception of sky channels on Sky digital.
    Originally thought it was poor connection where the dish lead connects to digibox as wiggling the lead at that point eventually got the signal back.
    However I have re-done the f connector but am still suffering intermittent reception probs.
    Signal strength is okay.
    Is it best first to replace the lnb on the dish and if that doesn't help to then look @ the pace box?
  2. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,365
    Bradford, West Yorkshire.
    +323
    Deezel,
    in your last thread on this subject I asked you which digibox you've got but you didn't answer. :confused:
    A. Dork
  3. deezel
    deezel
    Oct 25, 2004
    322
    +7
    Sorry AD
    Pace Sky Minibox RS 232
  4. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,365
    +323
    That's not the model number mate :)
    Pace BSKYB**** - on the sticker underneath.
    Probably the LNB at fault though. ;)
    A. Dork
  5. deezel
    deezel
    Oct 25, 2004
    322
    +7
    "Probably the LNB at fault though."
    OK, so any single lnb that fits a sky minidish ?
    The one @ present is a Sharp
  6. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,365
    +323
    Don't think I've ever seen a Sharp LNB on a Sky dish. :confused:
    New LNB's come with an adaptor if it's required. Don't worry, it's just a plastic sleeve to make it fit the feedarm of the dish. Easy DIY job.
    A. Dork
  7. deezel
    deezel
    Oct 25, 2004
    322
    +7
    Gave the lnb a closer inspection and noticed it was quite grimey.
    Gave it a wash & brush up and the picture has been great ever since
