Consoles to RGB/Component?
Discussion in 'Cables & Switches' started by acollins, Jul 22, 2004.
  1. acollins
    acollins
    Feb 21, 2002
    132
    16
    Portsmouth
    Is there a cable that I can use that would combine an Xbox, PS2 and Gamecube into the component/RGB connections on Plasma. I have seen cables which have a scart but not with RCA.
    The plasma has RCA socekts which can be used for either RGB or component.
    I dont necessarily need the perfect picture as the consoles are rearly used, its just that this is the only set AV sockets not being used.
    I dont own an xbox but would like to have the opportunity to just add it to the existing cable if i decide to get one.
  2. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    762
    midlands
    +17
  3. acollins
    acollins
    Feb 21, 2002
    132
    16
    Portsmouth
    Not sure if thats it or not :blush:
    One end needs to have adapters for gamecube,PS2 and ideally XBOX the other end RGB RCA (not scart i have no spare scart sockets)
    thanks
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Gamestation have a multi console AV cable, scart, S-video and possibly component £12.99 not sure if it is what you need though.
  5. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    762
    midlands
    +17
  6. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    762
    midlands
    +17
    failing that you could buy these and im sure it would work
    http://www.lik-sang.com/info.php?category=76&products_id=4088&#Product_features
    http://www.lik-sang.com/info.php?category=23&products_id=1696&
    http://www.lik-sang.com/info.php?category=83&products_id=1905&
    http://www.lik-sang.com/info.php?category=76&products_id=1468&
    total cost is around 35 quid i think the dearest thing being the cube component lead at 19 quid but you can just plug them all in to the box then to your tv should be quite easy to tidy cables
    then just select which one you want to play
    all in component so best pic quality for you aswell
