Console VGA connections
Discussion in 'Nintendo Forums' started by Pulsar, Sep 26, 2003.
  1. Pulsar
    Pulsar
    Jan 19, 2003
    3,137
    West Midlands - Stourbridge
    +332
    Hello Guys,
    I could do with some info from you knowledgable guys.
    I have decided to stop playing my console games on my projector, and I am thinking about buying a PC monitor to use instead. I will therefore be needing VGA output from each of the following consoles.
    1.Dreamcast
    2. PS2 (pal)
    3. XBOX (pal)
    4. Gamecube (pal)
    I know that a VGA box is available for the Dreamcast, and I have heard of a gamecube VGA cable, but haven't seen one. Can you help?
    Rob
  2. Demon
    Demon
    Dec 13, 2000
    988
    Cheltenham
    +75
    The XBOX has a good VGA box, in the same vain as the Dreamcast one.. i.e. it gives you proper 640progressive from the XBOX.. not some crappy line doubler..
    And then game needs to support HDTV (all but Toca Race Driver work for me), some games work in PAL as standard, but I have had much more success with the XBOX swithced to NTSC, but for this the XBOX reqires a modchip I believe... so may not be suitable for you..
    I got mine from XBOX VGA Site
    Other wise there are plenty of line doublers type boxes, that would give a picture, and some aren't too bad, its just a bit hit'n'miss..
  3. phenom2003
    phenom2003
    The XBox DOES NOT output VGA, hat box just takes in an s-video signal and upsamples. The dreamcast as you quite rightly said can just output vga, all the others need line-doublers. Try www.lik-sang.com for some
    Rich
  4. Pulsar
    Pulsar
    Jan 19, 2003
    3,137
    +332
    Thanks for the details guys. I think I will hold fire for a little while, and use a TV with RGB scarts instead.
    This does lead me onto another quaestion, can anyone recommend a good quality RGB scart switch box, preferably auto switching. I would need 4 inputs.
    Rob
  5. phenom2003
    phenom2003
  6. Pulsar
    Pulsar
    Jan 19, 2003
    3,137
    +332
    Thanks for the info.
    Rob
