Console to PC Connection
Discussion in 'Nintendo Forums' started by NellyM, Dec 15, 2003.
  1. NellyM
    NellyM
    Is it possible to connect my games consoles (PS2/Xbox/Gamecube) to my PC or to my PC monitor (I have 2 free analog ports) direct.
    Any Ideas ???
  2. Kramer
    Kramer
    If you want to use your PC, you'll need a capture card (PB-TV100 for example) & software such as Dscaler.
    For direct connection, you'll need a ProV which converts s-video or composite to VGA.
    There are dedicated "converters" available for some consoles but the ProV will work with any source.
    :smoke:
  3. fordy361
    fordy361
    You can get VGA box's of ebay for about £30 brand new I brought one when I didn't have a spare tv for my PS2. Its lets you use the monitor for PC and upto 4 consoles or video camera etc.
